LG Help Required 42LG3000
  • coopigeon
    • Jan 2014
    • 63
    • united kingdom
    Hi
    I have just been given a 42" Lg3000 lcd tv with a problem . As far as i can see it will power up well red light will come on but no picture or anything. if i hit the input button on the side the red light goes brighter flashes then goes off , cant get passed this part. Apparently if you plug a dvd player in it will play sound but no picture but i cannot test this at them moment
    Added small video of what the red light does when i press input button at side as i do not have the remote control for this set yet
    https://dl.dropboxusercontent.com/u/...511_174146.mp4
    any help would be greatly received
    Attached some pics
  • coopigeon
    • Jan 2014
    • 63
    • united kingdom
    Re: LG Help Required 42LG3000
    Revised look at tv .. the red led is dull if i hit the input button on the side it brightens up flashes three times then goes off. At no point do the screen try to light up
    • coopigeon
      • Jan 2014
      • 63
      • united kingdom
      Ok , i have picture if use flash light in dark but have sound ... anyway i can the inverter boards?
        Have you 24V at the inverter boards?
        • coopigeon
          • Jan 2014
          • 63
          • united kingdom
          Hi Tom .. where do i check for this and do i need set powered up?
            For a voltage check you almost always have the set powered up;
            the pins on the inverter should be labelled but in any instance you can usually find the group of pins all connected together.
            • coopigeon
              • Jan 2014
              • 63
              • united kingdom
              Ok i have 24.4volts at each inverter board for first 5 pins which looking at the wiring on the power board is correct
              • coopigeon
                • Jan 2014
                • 63
                • united kingdom
                should there be a voltage on the 2 wired white connectors leading to the outside of the telly ?
                  • 31288
                  if you mean the 2pin connectors going to the side of the panel - dont touch them.
                  those are the tube-drives, 300v+
                  • coopigeon
                    • Jan 2014
                    • 63
                    • united kingdom
                    roger that . Kinda freaky im watching it in the dark with a torch lol... tried disconnecting slave see if i could get a flash , tried disconnecting TCON no green led . just need to know either
                    1 how to get to ccfl area and check them caps out or check each inverter but dont know what to check for
                    2 how to check psu
                    3 was gonna just get a pair of inverters but reading some of the other threads this hasnt helped, as they dont historically go faulty together youd have thought disconnecting slave i might get 3 secs of life unless master gone.
                      • 31288
                      that's the first tv i'v seen with 2 invertors!
                      take them out & see if there is anything visibly bad on them under those covers.
                      maybe leave the covers off afterwards.
                      i know some of the large sony's had a design fault where the invertor overheated & failed because of a stupid plastic cover.
                        • 31288
                        check the invertor fuses.
                        small'ish white box on each inverfor marked "F" and a number.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Master/slave inverters, quite common for them to go faulty....
                          Check the BL-ON and BL-Dim pins, see what voltages on them....
                          TELEFIX
                          • coopigeon
                            • Jan 2014
                            • 63
                            • united kingdom
                            Hi yeah master and slave . covers are off and secured with a single screw. Nothing obvious visually .24.4v pins 1-5 . do you know what the reading should be on the F1 ? just reading a generic LG thread where BUDM diagnosed a bad black F1 which was stopping the inverters firing up. If anything transformers look bit crappy on solder joints but they look same on both sides so dont think thats the issue
                            • coopigeon
                              • Jan 2014
                              • 63
                              • united kingdom
                              are these on the inverters alistair on th ewhite block connector prob pins 6-14 somwhere?
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                Of the 10 odd wires to the inverter, some will be Gnd, some 24V.
                                There'll be two or three that will be marked, BL-ON/BL-Dim/PWM
                                Its the BL-ON and BL-Dim you need to check the voltage on...
                                TELEFIX
                                • coopigeon
                                  • Jan 2014
                                  • 63
                                  • united kingdom
                                  Taken this pic ,, Which is the BL-ON and BL-Dim pins? also the white fuse and black one in pic am i just checking voltage or some other setting?
                                  • coopigeon
                                    • Jan 2014
                                    • 63
                                    • united kingdom
                                    pins 1-5 24.4v
                                    pins 6,7,8,9,10,11,= 0 nothing
                                    pin 12= 4.8v
                                    pin 13=3.2v
                                    pin 14 = 0
                                    • coopigeon
                                      • Jan 2014
                                      • 63
                                      • united kingdom
                                      Hmmm the black F1 shows 24.4v one side and nothing coming out of the other although its a tiny end to get MM probe onto
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        So--with those voltages--Is the light on?
                                        If not--suspect either of the inverters or the BL tube/s its/themselves...
                                        TELEFIX
                                          Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                          by sam_sam_sam
                                          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                          I also have back when Light of America had these light bulbs available for yard lights
                                          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                          While the Lithonia lighting fixture has all most certain bulb failure
                                          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                          I have only had this light fixture for not more than a year if it...
                                          07-02-2023, 03:45 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                          LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 09:10 PM
                                          09-06-2024, 08:40 PM
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
