SOFTWARE SONY KDL40WE660
  • mnjoao
    • Feb 2022
    • 14
    • portugal
    Good morning, I have this Sony KDL-40WE660, when it turns on, the mark appears for a few seconds and then flashes 6 times, on pin 36 of CN9901 it has 3.2V, which according to the repair manual incriminates the main board, the software no longer It is available from Sony, would anyone have the software to update this TV.​
  • lotas
    • Jan 2016
    • 4859
    • Russia
    Show me where the 6th error indicates that the motherboard is faulty; usually the 6th error is related to a faulty backlight.
    Firmware update https://www.sony.co.uk/electronics/s...tware/00287620
    • Diah
      • Feb 2013
      • 6565
      +1 LED BL have one or more shorted
      • mnjoao
        • Feb 2022
        • 14
        • portugal
        Good morning, I have already forced the LED bars to be powered on, but the signals from the main board that go to the display disappear, (there are 4 LED channels, all with the same current when powered) the service manual says that when it blinks 6 times ; If on pin 36 of cn9901 the voltage is less than 3V it is the LED power supply, if it is higher it is the main board, in this case I have 3.2V Thanks anyway for trying to help Manuel Joao​
        • mnjoao
          • Feb 2022
          • 14
          • portugal
          I can't update, the brand appears three times and then flashes 6 times in red, I don't have a tool to reprogram the nands which I think are responsible for the failure
          • Russ17
            SONY KD-43X8305C - Not booting after software update
            by Russ17
            I have been given a SONY KD-43X8305C Android based 43" 4K TV.
            It received a software update which failed and then failed to boot after.
            I have tried holding Power and Volume down (-) then applying AC power, multiple times, with no success.
            The backlight is off, the main status LED is Off, the Mainboard heat sink gets slightly warm if left on for more than 30 minutes, showing it is getting power.
            PSU has normal outputs. Screen appears blank even with a torch test and no start up sound from Android is heard when powered on.
            10-23-2021, 02:41 PM
          • odie34
            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
            by odie34
            I am a hobbyist (not a professional) so please be gentle...
            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
            02-18-2024, 09:11 AM
          • eclectric
            Sony Bravia KDL-70W850B T-CON board / software update issue
            by eclectric
            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
            05-23-2022, 01:25 AM
          • Dangerousk
            Sony Android TV KD-49XE9005 4 red flashes
            by Dangerousk
            Hi there
            Have Sony KD-49XE9005 that has been working fine for some time now. switched on this AM and after a few seconds screen blank and red LED flashing 4 times. Tried resets and all responding as expected expected and after booting up, after few seconds of displaying normal broadcast picture, screen goes blank red led flashes 4 times in sequence.
            Anyone have schematics/service manual for this series. have checked the obvious items and caps test OK, voltages etc appear correct onwards.
            thanks
            D
            10-27-2024, 06:10 AM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
