this photo are the reflector hard plate burned by leds ?
Trying To Fix: Samsung THE FRAME backlight replacment - How to open display???
if its then the black shadow will remain... only the lost LED place will be little as first post photo... if i am in his case will just test the lost one if its okay will fitting it in place,Comment
Yea I've replaced a few and tried the old bad diffuser shields. They don't look nice. Generally bright spots show up. I just don't even try anymore and save all my good sheets. This one he might get away with very minimal. Guess we will see.Comment
The location of the warped and burned diffuser/reflector is about 1 foot from the left edge. If you look at the display when an image is showing that corresponds to the hardly noticeable bright spots seen in that location.
The rest of the diffuser/reflector looks perfect. Here's an example of the right side which is how most of the rest of the diffuser/reflector looks. I believe the unit was used in 24/7 picture mode over the years which
has a very low brightness setting. And very little TV watching. This may explain why the damage is as little as it is after all these years.
The replacement backlights have been ordered and should arrive early next week.Comment
Happy to report that this TV is back up and running with minimal visual blemishes or artifacts.
First pic is in darkness while the TV was in ART MODE (where the backlights turned to the lowest setting).
This is where you see the worst of it at the bottom. In a lit room you can hardly see anything.
Doubly true when the TV is out of Art Mode ... nothing noticeable in the light or in the dark.
Thank you guys for your help! Feels good to get it right this time!
Go to YouTube and type screen test. There's a video about 4 minutes. Click that and take a pic of white screen and red/blue (if you can) so we can see the alterations little more clear.
Figured it wasn't going to be perfect but since it wasn't horribly burnt though it wasn't going to be ridiculous. Nice well doneComment
See attached pics of the LCD test.
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
- Loading...
