LG 55LW5590 no display, no backlight
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Dear forum, I trying to fix up my LW 55LW5590 TV.
    The original board has graphical artifacts, so I odered a new one from Aliexpress.
    But with this board, the TV's backlight, nor the display won't turn on.
    The stabdly led turns white when I touch the power button, but nothing happens.
    I tried moving IC5202 and IC601 to the new board, but nothing changed.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4316
    • Italy - Milan
    Put the original board (we are talking of witch board?) and post photos of the video appearance, then we can judge if new board must work or not, generally appears you got the wrong board, LG ones have usually 3 codes and must match all ones
    • unimatrix93
      • Oct 2021
      • 343
      • Magyarország
      I don't have the original board anymore, but I do have photos of it's stickers/codes:
      The original board produced purple artifacts all accros the display. However the spinning LG logo and everything else worked perfectly. The problem was caused by the dying URSA5 Extrenal FRC IC. Cooling it with an active fan and bigger heatsink helped the artifact temporarely.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4316
        • Italy - Milan
        EBT... is one of the codes, i think this is the most important because it identifies the softwares, artifacts of witch shape? wasn't them circle shape and faded? in that case bad.leds can be..
        • unimatrix93
          • Oct 2021
          • 343
          • Magyarország
          No they were blocky purple like graphical glitches.
          I think I forgot to transfer IC602 from the original board, can this kind of IC be reprogrammed by Ch341A?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4316
            • Italy - Milan
            write me the printing on it..
            • unimatrix93
              • Oct 2021
              • 343
              • Magyarország
              The printing on IC602? It's F0514A.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4316
                • Italy - Milan
                It is a standby IC, there's no need i think, unless the remote has some keys not working or scrambled..
                • lotas
                  • Jan 2016
                  • 4578
                  • Russia
                  ​F0514A - micom Renesas UPD78F0514A
                  • lotas
                    • Jan 2016
                    • 4578
                    • Russia
                    It just gives commands to turn on the backlight, t-con, dc/dc convectors...
                    The processor often suffered on this chassis.
                    • unimatrix93
                      • Oct 2021
                      • 343
                      • Magyarország
                      But it has internal flash memory or it doesn't mattery which software is on it?
                      I was suspecting the CPU too. Should I try the "oven method" and see if it helps?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4316
                        • Italy - Milan
                        Have you got the schematics?
                        • lotas
                          • Jan 2016
                          • 4578
                          • Russia
                          Yes, here you go.
                          • lotas
                            • Jan 2016
                            • 4578
                            • Russia
                            Try heating the processor with a hairdryer, turn it on a little when it cools down and see.
                            • unimatrix93
                              • Oct 2021
                              • 343
                              • Magyarország
                              I have a hotair soldering station, a 858 clone.
                              What temperature and air settings should I use?
                              • lotas
                                • Jan 2016
                                • 4578
                                • Russia
                                Yes, set it to 350 + warm it up, this method will not fix it, only for the location that the problem is there...
                                Sometimes a full reboot helps, sometimes replacing the processor, but you won’t find a new one that works...
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4316
                                  • Italy - Milan
                                  sorry it is on post #1 (i'm at work, if master see me...) , page 52 , point n.2 =micom for key/IR...
                                  Lotas, old board is not present, new board is sold as good, no need to reflow, probably stickers doesnt match, is it right unimatrix?
                                  Post here the EAX code of main board, i search a picture, i point you the memories to swap, surely the NAND flash (TSOP48 package)
                                  Where is the FRC IC? i see none on the picture of Service manual.. only Processor
                                  • lotas
                                    • Jan 2016
                                    • 4578
                                    • Russia
                                    Sometimes you need to look at diagrams to see what micom is responsible for...
                                    • unimatrix93
                                      • Oct 2021
                                      • 343
                                      • Magyarország
                                      This is the original board EAX:
                                      And this is the new one:
                                      You are right about the EAX, it's doesn't match.
                                      The FRC IC is under the black heatsink next to the LVDS connectors.
                                      I already swapped the TSOP48 package next to the CPU, a Toshiba IC. I removed it back then from the original board for saving it.​
                                      • Diah
                                        • Feb 2013
                                        • 6363
                                        buying complete boards from aliexpress not a good idea... because they don't have working one...most all mainboards or power boards etc are parts didn't passed "QC" quality control at the manufacture so they sell it as used or some write as new... but 90% of them have fault.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          Acer Extensa EX2540-56BF + PowerCube Original Notebook 15 Specification for Upgrade or Repair
                                          This specification for the Acer Extensa EX2540-56BF + PowerCube Original Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-56BF + PowerCube Original boardview and EX2540-56BF + PowerCube Original schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-06-2024, 08:16 AM
                                          DELL XPS 9370 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9370 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9370 boardview and 9370 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9370 Notebook...
                                          09-06-2024, 08:23 AM
                                          09-06-2024, 07:33 AM
