technika lcd37-207
  • bboykes
    • Dec 2013
    • 28
    • england
    technika lcd37-207
    hello everyone i have got technika lcd37-207 with 17w20.1 power supply my problem is sometimes when i turn tv on from stand by blu light goes to dim and tv doesnt turn on it just show dim blue light if i unpluged tv and leave it 10 15 minutes and turn it on it work i bought repair kit for power supply and put it on still same and somtimes if u turn xbox on nothing on display and i have to turn it off and turn back on after 10 15 min display comes on
  • bboykes
    • Dec 2013
    • 28
    • england
    Re: technika lcd37-207
    i checked all supply on power board all correct all supply on the power board
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      can you recheck the psu part number as google has zero hits on that number
      • bboykes
        • Dec 2013
        • 28
        • england
        17pw20.1 vestel psu http://www.ebay.co.uk/itm/32-GOODMAN...item41802cbe11 i even checked all caps they all seems alright
        • anotherdude
          • Feb 2013
          • 488
          • uk
          what repair kit did you buy?
          are you sure that when your turning on that the image is there and it's not just the backlight not turning on?
          • bboykes
            • Dec 2013
            • 28
            • england
            http://www.ebay.co.uk/itm/17pw20v1-v...item3cda8692f8 this is kit forvestel 17pw20 psu no its not backlight mate i checked inverter its ok standby doesnt go to green when u press it goes to from solid blue light to dim blue light it not flashing it just dim blue light
            • anotherdude
              • Feb 2013
              • 488
              • uk
              if all your voltages check out, check the mainboard
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                07-01-2024, 06:34 AM
              • shamsudeen
                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                by shamsudeen
                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                07-19-2025, 07:14 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
                03-31-2024, 02:12 PM
