LG 60PK200 Vertical Bar - Intermittent
  • jstiene
    • Feb 2013
    • 148
    Hello. I have a 60" LG TV with a vertical bar that will intermittently appear. The TV will be fine for a month and then all of a sudden the vertical bar will appear for a few days and then disappear again for a long period of time. Is this is bad display or display connector or could it be possibly the buffer board? Usually I have encountered this problem where the bar is always there. In this case the TV works fine for a month or two then the bar shows up.
    Any suggestions would be greatly appreciated.
    Thanks!
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: LG 60PK200 Vertical Bar - Intermittent
    If the problem is random and intermittent then there's a good chance it's a loose connector.
    • JesusJones
      Samsung Plasma Intermittent Vertical Bars (repeatable) PN50B430
      by JesusJones
      Trash picked this plasma for parts and found it had some bad solder joints. It powered on after reworking most of the boards and seems like it may even work.
      The symptoms is, when showing a picture of bright (mostly white) intensity (within the affected area only) a vertical strip 2 3/4" wide will begin to fuzz out (just to the right of samsung logo, 16 3/8" from screen edge), and soon turns black (from top to bottom). Changing to a darker scene immediatley ater will cause the black stripe to fade back in (it fuzzes and clears up again) and it starts working just fine....
      04-13-2021, 01:45 PM
    • mopenstein
      Looking for Vertical IC for RCA Chassis CTC159L CRT
      by mopenstein
      I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
      Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
      I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
      09-24-2023, 10:41 AM
    • 265chemic
      Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
      by 265chemic
      Hi All,
      I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
      My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
      Below are some photos...
      03-23-2022, 04:53 PM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • protocold
      MacBook Pro 15" 2010 820-2850 intermittent charging
      by protocold
      I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
      I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
      when it is not intermittent:
      PPVBAT_G3H_CHGR_R is 12.07v
      when it is intermittent:
      When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
      when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
      data line on the battery...
      07-25-2025, 08:18 PM
