Sanyo AVP4232 dead no power
  • Dan_ve3rci
    • Apr 2014
    Hello all, I was given a Sanyo AVP4232 yesterday and was told that this tv would not power up. I opened it up today and did a visual inspection and there is no signs of any leaking or burnt caps. I have my suspicions that the voltage regulator(s) may be the culprit. I have tried doing a search of the forum to see if could find any information that could possibly help but came up with no results. Any help with this would be great and the wife would be in her glory's if I were able to get it working again.
    Dan
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • Andreas_de
    Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
    by Andreas_de
    Hello!
    i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
    Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
    Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
    04-12-2025, 10:38 AM
    03-31-2024, 02:12 PM
