TEAC LEDV32U83HDR(takes awhile to come out of standby)
  • Amraks
    • Nov 2011
    • 725
    Re: TEAC LEDV32U83HDR(takes awhile to come out of standby)
    Hey vinceroger this problem seems intermittent.
    as sometimes when i switch the set off at the power switch it will work fine.
    then you play with switching it off and on at the button a few times it will fault like above mentioned.
    I have done a factory reset on it, thats when the set behaves and fires up with out a problem
    • Amraks
      • Nov 2011
      • 725
      Hey Vince thanks for the reply.
      The problem seem intermittent as the Set will fire up fine most of the time.
      You have to flick it off with the mains switch on the TV and then flick it back on and press the button.
      also making sure I am hearing a whine coming from the transformer before pressing.
      I am wondering if its a transformer winding or possibly filter caps as these have not been changed.
      • vinceroger69
        • Mar 2012
        • 6714
        #43
        possibly worth trying replacing the caps to rule them out maybe budm or tom might have ideas i hate intermittant faults just when you think you found and solved it they come back.
        • Amraks
          • Nov 2011
          • 725
          Yeah intermittent faults are annoying.
          • Amraks
            • Nov 2011
            • 725
            check the factory menu
            Software checksum is ok. rules out epprom.
              Software checksum refers to the flash, not the EEPROM.
              • Amraks
                • Nov 2011
                • 725
                I see.
                Could the eeprom be faulty?
                • Amraks
                  • Nov 2011
                  • 725
                  I have just done a little test on the PSU.
                  Disconnected everything attached to it.
                  Tested
                  con2
                  (12v)13 & 12 = 14v
                  (5v)8 & 7 = 5v
                  (standby)6 = 5v
                  (ps-on)5 = 0v
                  (5v)4&3 = 5v
                  aren't all these meant to be switched off except for the standby.
                  • Amraks
                    • Nov 2011
                    • 725
                    Anyone have any idea.
                    I have posted some pictures of power supply.
                    Seems like the power supply is stuck on.
                    • Amraks
                      • Nov 2011
                      • 725
                      I have had a look at 3 resistors.
                      2x 250 OHMS tolerance 5% = 150
                      0.68 OHMS tolerance 5% = 9
                      Is this correct?
                      • Amraks
                        • Nov 2011
                        • 725
                        The 2 resistor were actually meant to be 150, I thought a band was red when it was brown.
                        Blue Grey silver gold = 0.68 5%
                        I am only getting 0.9 from this one.
                        • Amraks
                          • Nov 2011
                          • 725
                          I have fixed the main switching on problem I managed to reinstall the firmware.
                          We have transformer sequel still.
                          Would replacing a resistor 0.68 that is reading 0.9 fix this?
                          • Amraks
                            • Nov 2011
                            • 725
                            transformer squeal*
                            So you switch it off and you can hear a audible pulse coming from the transformer.
                            would this 0.68 ohm's that is reading 0.9 be causing this squeal or pulse from the transformer.
                            • Amraks
                              • Nov 2011
                              • 725
                              Here is the firmware if anyone wants it.
                              as its not on teac's website anywhere.
                              If u have the occasionally turning on problem it can be fixed with a usb key and this update.
                              Extract from Zip file first then copy to usb bin file, making sure file name matches "BIN_MSD_306.bin"
                              Obviously with out the quotes.
                              • Caleb
                                Smokin IC's
                                • Feb 2013
                                • 645
                                I would look for a leaky diode one that is loading down the standby supply but not enough to keep it from functioning. I only see one on the board excepting the bridge, maybe one of the output diodes. Resistors dont go down in value -I would say that resistor is fine
                                Liberating magic smoke one part at a time
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  Thanks tv has gone back to owner but if it ever comes back I will look into it more.
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
                                  • Crystaleyes
                                    Samsung BN44-00259A standby question
                                    by Crystaleyes
                                    Hi all.
                                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                    08-11-2023, 05:15 AM
                                  • psssst
                                    Yamaha TSX 120 Standby Problem
                                    by psssst
                                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                    03-01-2024, 07:25 AM
                                  • reessi
                                    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                    by reessi
                                    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                    Years ago it had some bulging caps...
                                    04-26-2021, 11:42 AM
