Panasonic TC-P50C2 Lines in picture
  • cliff_hootarski
    • Jul 2006
    • 411
    Planning on picking this one up today. (See Pictures)
    I'm thinking loose cables or faulty "A" board.
    Any other suggestions?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50C2 Lines in picture
    I'd expect that would be A board.
      agreed we've seen this before and it was caused by an A board fault.
      • cliff_hootarski
        • Jul 2006
        • 411
        I'll update the thread when I find out anything.
        Thanks for the input.
        • peekywhop2
          • Mar 2015
          • 5
          I have similar problems to this any help?
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • adamp91gvm
            hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
            by adamp91gvm
            as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
            09-10-2025, 12:13 PM
          • hendue
            BenQ 2765HT vertical lines, no picture
            by hendue
            I was trying to fix the monitor, which was giving me the following pictures:
            It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
            I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
            Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
            I turned around...
            09-09-2025, 08:27 AM
          • FZG
            Panasonic AG-1000B VHS player with bad picture quality
            by FZG
            Hello!
            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
            I want to know, is this something that could be solved by recapping or is the video head likely gone?
            Also, what mechanism is this?
            Any feedback is appreciated!...
            05-06-2024, 07:16 AM
