Toshiba 42HP66 - Pulsing -Vy
  • capkid
    • Oct 2010
    • 1339
    I sold this TV to a friend over a year ago after replacing the IPMs and fuses, and it now has sound and no picture again. The voltages check out, except for the -Vy, which pulses between -1V and -2V. The pulsing is audible. I disconnected the Y-buffer from the Y-Sus, but the pulsing is still there. It's most likely a Y-Sus issue, and I could probably find the culprit, but I don't have a whole of time to spend on this TV. Has anyone experienced this issue? What was the resolution?
    Y-Sus part number is 6871QYH053B.
    LG Plasma Mal-Discharge Correction Service
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Toshiba 42HP66 - Pulsing -Vy
    With the reputation these LG based sets have--Its likely the IPM has failed again, loading down the -Vy
    Sadly, IPM's dont always fail the same way, making diagnosis sometimes--Stressful!
    TELEFIX
    • capkid
      • Oct 2010
      • 1339
      Yeah, I was thinking the IPM may have failed again. Neither of the fuses on the Y-Sus is blown, so I was hoping this might be a quick and cheaper fix.
      • capkid
        • Oct 2010
        • 1339
        Well, it looks I have a shorted mosfet (IRFP4232), so I'm going to replace it and the other two that are chained to it.
        • capkid
          • Oct 2010
          • 1339
          I replaced the three IRFP4232 mosfets, and I now have a whitewashed picture. The -Vy is reading -243V I guess I have more work to do. Crap.
            Have you tried adjusting -Vy down?
            • capkid
              • Oct 2010
              • 1339
              I turned the pot, but the voltage didn't budge. I may look at the card on which the pot is installed.
              • Ltank
                • Jun 2013
                • 776
                Sometimes the problems are simple, but is the pot good? With the power off have you varied the pot a bunch of times to clean it or sprayed cleaner to maybe clean the wiper? I myself sometimes dig too deep for a problem when it's right in front of me staring me in the face!
                • capkid
                  • Oct 2010
                  • 1339
                  The pot appears to be good; I'll take a closer look tonight. My line of thought is on par with your thinking. My first thought was to not dig too deeply into this issue and start removing and testing a bunch of components, since replacing the fets yielded a result that's close to what's expected. Several years of damaged boards and components from hacking around have made me a little wiser
                  • Shinju
                    • Mar 2014
                    • 1239
                    I have one of these sitting in the Garage, not sure I want to deal with it if they fail even after replacing parts.
                    Its a 720p how is the quality of it picture wise?
                    • capkid
                      • Oct 2010
                      • 1339
                      The picture isn't bad. I responded to your thread regarding the IPMs. The problem with these TVs is that the typical failure points (IPMs) can be expensive to remedy. IPMs cost around $40 each, and it's recommended that the Y-Sus and Z-Sus IPMs be changed at the same time. The fact that this TV failed again after one year is disappointing. Fortunately, I live near the plasmafix.com shop, so I got the replacement mosfets quickly and cheaply.
                      • Shinju
                        • Mar 2014
                        • 1239
                        Nice, you and I are pretty close. I got a Vizio that is also giving me some hell too.
                        Thank you for the response in my thread, I will check into it!
                        • capkid
                          • Oct 2010
                          • 1339
                          Oh, yeah, you're in Kirkland. Cool. Hopefully, you can get things figured out.
                          • capkid
                            • Oct 2010
                            • 1339
                            Well, it looks like the -Vy pot is fine. I measured voltages on that card, and the transformer reads 185V on the primary and is converted to -220V. I'm wondering if I have a cap issue on the secondary side of that transformer. More to come...
                            • capkid
                              • Oct 2010
                              • 1339
                              I tested most of the components on the secondary side of PS101's transformer, and the only one that seemed a little suspect is the cap at C22.
                              C22: ESR = 60, but I'm skeptical because it appears to be in parallel with a R21. The resistance across C22 is 10K ohms, which is the same as the value of R21.
                              C29 is in circuit with the U21 (KIA431A), and I couldn't get a reading using the ESR Micro V4 or the Fluke 87-III.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                There's a couple of 10uF 400V caps on the secondary side of that board--If you have them, worth replacing while board is out, although I suspect this wont actually cure the problem, seeing the output is present....
                                The ESR of these high-voltage low value electrolytics should be below 3 ohms, IME....
                                TELEFIX
                                • capkid
                                  • Oct 2010
                                  • 1339
                                  I may have to pull them to check, since the two on the secondary side of the transformer are in parallel - getting 2.6 ohms. The cap on the primary side is 3.6 ohms, so I may change it to prevent a future failure. I'm thinking one of The SMD caps or the regulator is bad. Do you know the values of the SMD caps?
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Unfortunately--no, I dont know their values.
                                    IF they are the ones across the electrolytics, they'll be pretty small values seeing they are subject to the high voltages....
                                    The Datasheet for the regulator should indicate roughly what they are...
                                    TELEFIX
                                    • capkid
                                      • Oct 2010
                                      • 1339
                                      Ok. I removed the 10uF 400V caps from the board. The capacitance of each cap is just about right on spec, but the ESR is a bit off.
                                      Secondary side caps: 4.9 ohms and 3.5 ohms
                                      Primary side cap: 3.0 ohms
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        The 400V caps seem fine. I found this diagram that appears to have the C22 cap circled that I mentioned earlier. Of course, the cap's values aren't listed. I measured the cap in the same location on the PS102 board with it still installed, and it measures 0.22uF and 24.5 ohms ESR. From what I can tell, the PS101 cap is physically smaller - I got 0.11uF when I measured it.
                                        http://obrazki.elektroda.pl/8808509600_1323159379.jpg
                                        http://www.elektroda.pl/rtvforum/topic2153162.html
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
