LG 50PJ350 - Not turning on, clicking noise
  • Josh094
    • Jul 2013
    • 17
    Ok guys, I've got an LG 50PJ350 plasma here which has intermittent issues with turning on. At times it will turn on, work fine for a few hours and then after I turn it off and leave it for a few hours it won't turn on again. It makes a clicking sound, the standby light goes off but the screen doesn't come on. It then clicks a few more times and the standby light comes back on.
    I ordered and fitted a repair kit which replaced a regulator IC, fuse, diode, 3 capacitors and a couple of resistors (kit here) however there has been no change and the problems persist. Just wandering if you guys would be able to provide any assistance in diagnosing the problem.
    Thanks in advance
  • Josh094
    • Jul 2013
    • 17
    Re: LG 50PJ350 - Not turning on, clicking noise
    Had a better look at the board and it turns out there was a bad solder joint. Repaired it and now it seems to be working fine.
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • NConstantinou
      HP Z840 workstation power supply clicking noise
      by NConstantinou
      No power
      i have the above ps which i change the TOP258eg ic.
      Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
      i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
      the colours look like R,R,W or silver,G Bl.
      Thanks...
      12-25-2024, 02:24 AM
    • LGhost
      Samsung ue55d8000yuxxu turning on/off and clicking
      by LGhost
      Hello everyone! This is my first thread asking for help and I'm new here so please be nice
      I'm trying to repair a Samsung TV but not having much success so I've came across this forum and it seemed kinda nice and friendly. The TV is clicking on/off (relay) and I can't seem to put my finger on the issue. The image looks fine (since I can get a glance at the "Smart TV" logo when it boots). But it's just an endless loop of on/off. If I disconnect the mainboard from the PSU it stops doing the "clicking" sound but that's about it. I've already got a used mainboard...
      05-22-2023, 05:40 AM
    • meeotch
      Samsung PN64H5000 clicking when powered, then stuck in standby
      by meeotch
      My PN64H5000 shut itself off/on/off a few times in succession last night, then refused to turn on again. When I first plug it in, I get five clicks coming from the power board, and the red standby light on the front goes on and off, as does the little green LED on the logic board. After that, the red standby light comes on after a couple of seconds and stays lit, but the TV will not power on. Confirmed by leaving it unplugged overnight.
      I opened it up, and didn't see any bulging caps, burnt PCBs, or anything else obvious. Tested the two fuses I saw on the power board (one removable,...
      09-27-2021, 02:57 PM
