Panasonic TC-P50S2 Snowy Picture
    replied
    Re: Panasonic TC-P50S2 Snowy Picture
    the snow is probably a bad cap letting ripple/noise into the processing circuits.
    i'd replace all the small electrolytics - if that dont fix it, try the large ones.
    replied
    Hence why I call it a stupid price, I really do not know how these companies sell any boards at those prices. Maybe to warranty companies only.
  • rlhowelljr
    replied
    well that would not help for little more I can buy a new TV.
    replied
    You can often buy the board through something like Sears or a parts distributor but you would be looking at a stupid price ($300+) in most cases.
  • rlhowelljr
    replied
    I am going to try to call Panasonic tomorrow to see if they will sell me the board. Not sure if i will have any luck with them since i am not an "authorized repair center"
    replied
    It's a common failure and Panasonic panels are sold in lesser numbers and are more resilient to being broken unlike Samsung panels so it's rarer to find a cracked one for parts use.
  • rlhowelljr
    replied
    this board seems pretty tough to get for a TV that is less than 4 years old.
    replied
    That will probably not fix this problem unfortunately.
  • rlhowelljr
    replied
    Checked online and can only find a repair kit for that board. The kit says it is for most problems with the SC board but lists blinking fault codes which mine did not have.
    could this work?
    "The Panasonic TXNSC1LQUU SC Board Component Repair Kit includes all necessary components to repair common failures on the main SC board. Symptoms include will not turn on and power light will blink 4, 5 or 7 times."
    Specifications: Kit Includes
    Description Quantity Board Location
    Transistors 8 Included With Kit
    Resistors 3 Included With Kit
    Diodes 1 Included With Kit
    Integrated Circuits 1 Included With Kit
  • martino
    replied
    I can check Monday when I'm back from dog seminar. I might have that board.
  • tw2005
    replied
    Originally posted by tom66
    I'm pretty sure the C2 is no go due to being 720p panel?
    Can try some diagnosis there is a schematic, I am thinking it is the init-field FET that is not being driven correctly, best to have a scope but can see what is possible with a multimeter.
    Fixed. Cheers
    Should have picked that, copy/paste straight from SJ without checking they had it correct, which obviously they don't.
    replied
  • tw2005
    replied
    The first shot is the SC board.
    The second is of the SU board bolted/connected to the SC board.
    Could be a very hard board to source.
    TXNSC1LQUU, TNPA5105AB
    Panasonic
    TC-P50S2 TC-P50U2, TX-P50S20B, TX-P50U20B
    Edit: TXNSC11FEK50 is another part number.
  • rlhowelljr
    replied
    There are a couple of part numbers on the board. Can you tell me which to use? Also, where can I find the prefix? I think it is a TNPA5105 but no prefix.
  • martino
    replied
    Did you try and look for a cold solder joint?
  • rlhowelljr
    replied
    Thank you for all of your help tom66. I will try to locate a replacement board.
    replied
    With a modern Panasonic panel such as this, simply locating a 50" series 2 board (TC-P50G2, TC-P50V2, TC-P50S2) with the same part number and suffix should be OK. You need to avoid getting a 3D board (TC-P50VT25 comes to mind) or a 25 series board as it will likely be different. Also you can't use a 42",46",58",65" board without considerable modifications, so best to avoid those.
  • rlhowelljr
    replied
    Yes the new board will probably be the best solution as my soldering skills are not the best and will be unable to obtain an oscilloscope. Do you know a good place to get a new board will be? Will there be any adjustments to make after changing the board or will simply swapping for a new one be sufficient?
    replied
    Yes I'm aware of that, the problem is it's probably going to be down to a very small component in that circuit so locating it will be hard. You would probably require an oscilloscope.
    Maybe the best bet for you is to locate a replacement board since you've narrowed the fault down to one board.
  • rlhowelljr
    replied
    It is on this board. I think it is the SC. I have no idea what a VSET or INIT-F is.
  • FZG
    Panasonic AG-1000B VHS player with bad picture quality
    by FZG
    Hello!
    I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
    Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
    I want to know, is this something that could be solved by recapping or is the video head likely gone?
    Also, what mechanism is this?
    Any feedback is appreciated!...
    05-06-2024, 07:16 AM
  • Bazfletch3
    Panasonic TH-65FX800A backlight LED's working but picture is very dark
    by Bazfletch3
    Hi all
    While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
    I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
    From there I envisaged that the backlighting wasn't working, however...
    01-08-2024, 10:18 PM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • JJAAMM
    by JJAAMM
    Problem
    07-06-2023, 06:01 AM
  • mar1in
    Panasonic TH-55AS670A no picture no sound
    by mar1in
    I've got this Panasonic TV here with the following symptoms:
    * Standby Light is solid RED
    * Turning on using the Button on the TV (long press) would change LED to blinking GREEN
    * After a couple of seconds, LED is solid GREEN and without picture or sound.
    I've tried a couple of things before tearing it apart:
    * Resetting using various combinations of powerbutton and volume buttons pressing down while booting.
    * Activating Self Check according to service manual using IR Blaster (we have no remote unfortunately)...
    09-10-2023, 11:10 PM
