White very bright picture on LVQ40HLA VisionQuest
  • paulstef
    • Dec 2013
    • 724
    I'm looking for a schematic of this mainboard 520-MSD119C-010C.
    Google tells me that it;s also in the Sceptre X32BV.
    The TV has a very bright picture which cannot be adjusted. The backlight CAN be adjusted though. Removing the signal output connector from the main board results in having only the dark backlight glow. So that seems to be ok.
    The picture is so bright you can barely see the picture. It's as if brightness and contrast was adjusted to their maximum value.
    The guy I have it from told me someone sat on the remote control and after that he had this problem. Sounds weird.
    Anybody knows if a schematic is available or what could be the problem or if there needs to be firmware reflashed or something?
    Thanks!
    Re: White very bright picture on LVQ40HLA VisionQuest
    This might be another gamma IC failure. It can cause this effect, completely unrelated to main board. Can you supply a picture of the fault & a picture of the T-con board?
    • paulstef
      • Dec 2013
      • 724
      Here is a picture of the fault. Brightness contrast and other picture related menu adjustments have minimum effect on the picture. The backlight adjustment works. The picture is colored.
      I will post a picture of the TCON later.
      I don't know much about the TCON, i.e. never had to replace one. Why does the picture go black when I remove the cable from main to TCON? I didn't remove the board yet...
        That definitely looks like a gamma fault.
        The T-con converts the video signals that the main board produces into a format that the LCD panel can accept. It also typically generates the various voltages that a panel requires (VON/VGH, VOFF/VGL, AVDD, and VDD.)
        When the power to the LCD panel is removed, because the T-con is disconnected from power, the pixels go back to their natural state; on most panels this is black. Earlier panels went white with no power.
        Look closely at the panel. Can you see a dancing dots pattern? Every second dot flickering? This is one effect that can sometimes occur with a gamma fault due to mis-matched curve voltages.
        • paulstef
          • Dec 2013
          • 724
          Thanks for the explanation. No I couldn't see dancing dots, but I didn't look REALLY closely. Now I have it partly disassembled. Will have a look at it later.
            No worries, we can still check the gamma curve voltages to see if the IC is bad or not.
            • paulstef
              • Dec 2013
              • 724
              Here is a picture of the TCON board. It says T400XW01.
              • paulstef
                • Dec 2013
                • 724
                Is the gamma IC the 48 pin TQFP package ? The datasheet says "voltage buffers that buffers reference voltage for gamma correction". If that's it it would be easy to replace. Otherwise, how can I actually check what's wrong with the TCON? I know they cost next to nothing but I still would like to find out what's wrong.
                The other two big ICs look like a CPU and RAM but I didn't really look up their datasheets.
                  Yes, that's the chip.
                  Just above & to the right there's a series of points which are labelled VGAMA1 thru VGAMA22
                  https://www.badcaps.net/forum/attach...7&d=1398218428
                  Check the voltage on each point with the board connected.
                  • paulstef
                    • Dec 2013
                    • 724
                    Ok, I'll check them tomorrow. Thanks a lot .
                    • paulstef
                      • Dec 2013
                      • 724
                      So I have:
                      VGMA1: 15.29V
                      VGMA6: 15.16V
                      VGMA9: 15.16V
                      VGMA10: 15.04V
                      VGMA11: 15.04V
                      VGMA12: 6.64V
                      VGMA14: 4.9V
                      VGMA17: 4.13V
                      VGMA22: 0.35V
                      REF6: 14.45V
                      REF9: 14.3V
                      REF14: 4.8V
                      REF17: 4.08V
                      VGMAREF: 2.48V
                        Your gamma IC is bad. Replace the IC marked AS15 and it should be good. Alternatively replace the entire T-con board.
                        • paulstef
                          • Dec 2013
                          • 724
                          Thanks! I would like to understand better though.
                          How do I determine that it's bad? What voltages should there be? Are they similar for all panels? I assume the higher the voltage the higher the transmittance for the pixel?
                          Since this IC seems to be a simple amplifier how do I know it's not the input signal that's wrong?
                            I will link you to a couple of pages from my ebook (still a big, big work in progress) to help you understand.
                            • paulstef
                              • Dec 2013
                              • 724
                              Great reading. Made certainly more sense to post this here than to explain it several times.
                              Anyway I guess I will have to read more on this subject. So the gamma IC actually creates fixed voltages in certain steps and the average of all of them should be half of AVDD, 15.77V in my case.
                              For the sequence I posted the obviously wrong voltages are 5x equal of 15V, is that correct?
                                Half of AVDD in your case is 7.5V and this is true for 99% of large LCD panels used in TVs. (Laptops & phones tend to use 6 to 9V AVDD...)
                                The voltages should either increase or decrease but they can only do one. They can't increase, decrease, increase. That's bad. That's test 1 and detects 90% of failures.
                                The second test is to virtually split the curve around the middle VGAMA (11 in this case.) For the lower values, try to mirror them about the axis so they line up with the upper values. As you can see this is not possible. This is test 2 and detects most other failures.
                                Failing that compare to the reference curve in the ebook...
                                Yes the real killer voltages are the first half stuck at 15V which is causing the LCD to drive all pixels full white for half the pixel cycle. (VGAMA22 & VGAMA1 represent the same light level... it's complicated.) This is why your picture is whited out.
                                I missed a figure in that text. It doesn't make much sense without it. Let's try this again...
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  It IS complicated. We will wait for your ebook. It will certainly be of great help for many people.
                                  Will swap the IC and post the results. (I wonder why they burn so easily, must be out of specs or near max ratings somewhere)
                                  Thanks a lot!!
                                    On EEVBlog forum, we haven't reached any consensus as to why these might be failing. So far, we don't believe it to be a thermal failure (they run about 40°C when working which isn't going to shorten life significantly) nor is it believed to be a board design issue (since it happens with tons of boards from different manufacturers.) Personally I think it's a design flaw, possibly leading to a thermal event (transient short) in the IC... but I'm really not sure.
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      Yes, it was the IC. TV works now. (just has one stuck green pixel)
                                      Thanks Tom! Your help is much appreciated!
                                      • Schwoin
                                        Philips 243v5lhsb00 Monitor Picture too bright
                                        by Schwoin
                                        Hey everyone,
                                        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                        While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                                        you can see them on the top half of the photo.
                                        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                        03-21-2023, 12:40 PM
                                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:46 AM
                                        MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        09-06-2024, 07:29 AM
                                        MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:25 AM
                                        MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
