i got this tv from a friend and the screen look purple and dim. the panel is a Panasonic mc127h27d12...when i push the on/off switch there a high pitch sound??? anyone ave see this problem?? cut and paste the link for my mini video==https://www.facebook.com/photo.php?v=10152382951074312&set=vb.659709311&type=3&theater
sanyo dp50749-02 picture problem
by doorzonHi all,
hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
See attached picture.
I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
However, this could also be related...-
08-12-2023, 02:36 AM -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by retrorepairHello gurus, hope you can assist me...
I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
Thanks in advance.2 Photos -
by KYBOSHHello all
I pick this up free as a repair project for the holidays.
The original symptom was power cycling after 3-4 seconds with a single red light flash.
To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side... -
by RusengaHie techs, I have a samsung plasma TV which when plugged in shows a very dull reddish image. Tested some voltages and below is what I get:
Note the green light on the tcon flashes every second.
Power supply board:
PS on 0v
Stby 5v
VS CON 1.72v
VS ON 3.2v
VS 208v
VA. 57v
X buffer :
Svt vs 209v
Svt xout>flactuating between 280 to 900v
Y main board:
Svt vs. 208v
Svt ve. more than 1000v
Svt yg c More than 1000v
Svt yout flactuating between 400v and 1900v
Svt... - Loading...
