Samsung UN40C6300 clicking fast
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this TV and trying to repair it, but I need some help.
    I have jumped the STB to PS and BL and the backlight turns on and stays on without clicking.
    So it's a mainboard issue.
    I'm thinking to try resetting the EEPROM, what can I lose?
    I don't know which one is the EEPROM. The clsoset ICs that I have found are the same both of them, they are 8 pin and there designation is S24CSO. These could be the ones I'm looking for? They are EEPROMs, but why there are two of them?
    I haven't made a picture yet, but here is shopjimmy's picture, I have circled the two ICs.
    Any help would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Samsung UN40C6300 clicking fast
    There are two 8 pin ICs near the CPU, but those are some buck regulators(Zxxx).
      Try SAMYGO wiki... there are locations for EEPROMs there, I think it will be SPI flash though, the C-series LCD flash may or may not work.
      • tibimakai
        • Jan 2012
        • 3680
        Thanks Tom for answering, but on that site I don't see anything similar to my board.
        What do you mean by SPI, different type of EEPROM? The one with a paper sticker on it? If yes, what that means?
          SPI flash, yes you can think of it as an EEPROM (it's not, but it's similar.) It stores the software for the TV after the boot loader has started. (Running Linux, usually.) If it is corrupt it will not boot usually hence the loop clicking. Not sure which one it is but if you post the part# it can be confirmed.
          • tibimakai
            • Jan 2012
            • 3680
            Should I remove that paper sticker?
              Yes, but keep it or note down what's printed first.
              • tibimakai
                • Jan 2012
                • 3680
                What is interesting that I had a very similar TV in the near past, it was the UN46C6300 with the same issue, it was clicking slower then this one.
                By replacing the motherboard, it fixed that TV.
                Now I still have that board and I connected to this TV and it does the same thing slower clicking. It is not even compatible this board with the 40".
                It would be nice if I could repair that board also. These are hard to find.
                They are like $130, if you can find them.
                • tibimakai
                  • Jan 2012
                  • 3680
                  It seems like this is the part number# Samsung KFG1G16U2C-A1B6.
                  I couldn't locate a datasheet for it yet.
                    Reprogramming that IC will be too difficult, it is BGA. I think the only thing you can do is replace the board, sorry. Common issue with C-series Samsungs.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      OK thanks. I thought that I will end up like this, but I have never looked into resetting an EEPROM and I thought that, this time it would be a good time.
                      Oh well, maybe next time.
                      • cliff_hootarski
                        • Jul 2006
                        • 411
                        I recently sent a mainboard to this company when I could not find a replacement board:
                        http://www.moduslinkptstvboards.com/
                        They are not cheap, however if you can't find one anywhere else....
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I'm reviving this very old thread, because I have found a cheap board for it.
                          It turns out that the "new" board clicks as well, but slowly.
                          I have forced the TV to turn on with two resistors and the TV is on with backlight.
                          The power supply could still be the problem, causing this slow clicking?
                          Funny story happened when I was removing the old mainboard from it.
                          When I was pulling on the board(has those big heat transfer pads) after removing the plugs and screws, one of the BGA IC fell off. Maybe this was my problem from the beginning? Half of the solder boards are on the IC and the other half on the PCB. So they sheared off in half.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Anybody? I need to answer to the Ebay seller and I'm not sure what to say.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              If I would measure all the voltages, at the connector between the PS and mainboard, and they are all there, that would suggest that the PS is OK, right?
                              The backlight turns on, if I force it to turn on, with the two resistors.
                                • 12332
                                • U.S.
                                Maybe try reflowing the bga.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I don't know, if I should mess with a board that most likely I will return.
                                  I'm seriously considering, re-soldering the fallen bga on my own board.
                                    • 12332
                                    • U.S.
                                    Indeed that IS what I meant, re-flow original.
                                    • B0r1s
                                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                      by B0r1s
                                      PSU - BN44-00878A
                                      Symptoms:
                                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                      A weak clicking sound was coming from the transformer.
                                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                      Progress:
                                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                      01-17-2023, 04:58 PM
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
