help with samsung pn58b550 plasma
  • mattstolte
    • Dec 2013
    • 612
    • usa
    ok I got this plasma and I still hear the sound of it turn on and it says on, so im starting to think maybe main board??? the main logic control green light is flashing is that normal? but I cant get picture. I have proper vs and va readings, I disconnected the bottom scan drives and buffers but am not getting inverter or picture, any advice where to go next? thanks
    Re: help with samsung pn58b550 plasma
    Check the Vscan and Ve on the Y-main and X-main respectively. How rapidly does the LED flash? Once a second or once every 5~7 seconds? Also try test pattern jumper.
    https://www.badcaps.net/forum/showpo...61&postcount=2
    • mattstolte
      • Dec 2013
      • 612
      • usa
      The led flashes every second.. also what do u mean check the vscan and ve? I'm new to this plasma stuff. I was thinkn could it be the main board?
        Maybe, but you can't be sure until you make tests. It's reasonably rare for a main board to produce audio but no video; not impossible, but rare.
        Post a close shot of your X- and Y-main boards, clear and in focus, I will highlight where to test.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Ok tom I will do later when I get back there. Thanks for ur help. You do help me a lot. I'm not here just looking for answers. I'm trying to learn. I have like 10 tvs I'm working on. I'm pretty good with lcds but plasmas are complicated, and I always avoided them but now I'm going at them ready to learn how to do it
          • mattstolte
            • Dec 2013
            • 612
            • usa
            tom here are the pictures. yes the main logic control is blinking green light every second, also I hear a buzzing sound, sounds like its coming from under the main or the zsus, when I unconnect the z sus ribbon from logic control the buzzing goes away, here are the pictures[/ATTACH]
              Is there any chance you can get a clearer photo, not from an angle? If not, can you take pictures in sections. Need to be able to see small text.
              • mattstolte
                • Dec 2013
                • 612
                • usa
                Tom is there anyway you can tell me what small print to look for? Its gonna be hard for me to get such a good pictuyre being this is a huge tv the spot i have it in doesnt have that good of light for my phone. I can follow great directions if u can help lead me, thanks
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  I disconnected all buffers and scan drives and still couldn't get a picture unless im doing it wrong? anyhelp? is the green light on the main logic control suppose to be constantly blinking every second?? I have sound but no picture?
                    1 blink sec is OK.
                    I am looking for Vscan, and Ve or Vb testpoint.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      Tom I am going to my shop now tell me where these will be and ill take pic
                        Each board is different, just look for labels.
                        • mattstolte
                          • Dec 2013
                          • 612
                          • usa
                          will any of this help?[/ATTACH][/ATTACH][/ATTACH][/ATTACH][/ATTACH]
                            ...do any have a label Vscan or Vsc? I can't see one immediately. It is usually very obvious...
                            • mattstolte
                              • Dec 2013
                              • 612
                              • usa
                              The one says vscan., the other one says. DXR,xr,vb,xs,xb ???
                                Whrere, can you provide a picture?
                                • mattstolte
                                  • Dec 2013
                                  • 612
                                  • usa
                                  I mean it says them markings on the board
                                  • mattstolte
                                    • Dec 2013
                                    • 612
                                    • usa
                                    is this what u wanted?
                                    • mattstolte
                                      • Dec 2013
                                      • 612
                                      • usa
                                      Tom I also did this check with prongs 3 and 4 and still nothing
                                        That marks the adjustment point, but we're still looking for a place to test it. Since 3-4 jumper did not work, it is unlikely to be a main board fault.
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • bcstedt
                                          Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                          by bcstedt
                                          Just starting to crack into this one and wanted to get the ball rolling.
                                          At power on (plug in), power light on, relays click, repeat (sometimes)
                                          After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                          Removed Y-Main for inspection and testing
                                          This pic from:
                                          PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                          12-15-2023, 10:30 AM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • Biruslapio
                                          Samsung PL42C450 plasma X-Main IGBTs
                                          by Biruslapio
                                          Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
                                          It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
                                          Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
                                          04-08-2022, 01:16 PM
