ps50b51 ymain drama
+ More Options
Posts
  • wreksta
    • Aug 2013
    • 508
    • england
    ps50b51 ymain drama
    hi l I have a faulty y main Y board # Lj41-05905a,
    on this tv its the only fault
    this is where im pulling my hair out I have been through 4 mosfets on this board each time I repair it I power on click pop click click click mosfet shorted its the the very top 1 near the main power conector for the board all fuses test fine as do al the 6r2 resisors that are said to fail
    why is this mosfet keep blowing
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: ps50b51 ymain drama
    Post photos of the board and which mosfets you are talking about. I just repaired one of these boards the other day, and it had a small shorted smd transistor and one open 6R2 resistor that I found. It would continue to short two of the pins of the mosfet if not replaced.
    • wreksta
      • Aug 2013
      • 508
      • england
      dnt v a picture mat camera not re at he moment can you help m out with his transistor please location etc
      my y main is the AA1
        Did you replace the IGBT driver at the same time as replacing the transistors? The driver can be damaged by shorts, which can then kill the new IGBTs... leading to a never-ending drama of dying transistors.
        • Glitcher
          • Mar 2013
          • 673
          • USa
          Which mosfet keeps blowing RHJ3044 or IRFP4332?
          • prodigy83
            MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
            by prodigy83
            My reference only: TT10141.
            Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
            Mosfet specs are as follows:
            Chip markings:...
            03-12-2024, 01:38 PM
          • corrize
            IO power board, mosfet leak ?
            by corrize
            Hello, I have a basic power board (from DSLR camera), this board convert 12v in some other voltages (there is no charging chip). This board is disconnected to other, so it feed nothing, the outputs should be open lines.
            When I plug the battery (12v), I measure a weird behavior…
            I found a mosfet , with 12v at source and gate, and the voltage decrease very slowly at drain : 8v… 7v… 6v… I measured with meter source-drain : 45KOhms, so can I deduce surely the mosfet has a leak (and it is dead) pls ?
            The mosfet datasheet, but it's basic one.
            https://pdf1.alldatasheet.co...
            03-05-2023, 04:49 AM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • MacGyver's paperclip
            what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
            by MacGyver's paperclip
            TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
            07-01-2023, 12:12 PM
