hitachi p50s601 no clue where to begin>?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    plug it in and it goes from red standby to blue on and nothing?? I attached picture , where do I start?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    Re: hitachi p50s601 no clue where to begin>?
    Originally posted by mattstolte
    plug it in and it goes from red standby to blue on and nothing?? I attached picture , where do i start?
    • bodaciuos
      • May 2011
      • 43
      start by reading.. https://www.badcaps.net/forum/showthread.php?t=25810
      and all stickys:: https://www.badcaps.net/forum/forumdisplay.php?f=31
      itll give u a good idea of what u will be getting into..
      • Glitcher
        • Mar 2013
        • 673
        • USa
        This model has a common from with shorted buffers and two large caps on the PSU. However looking on your photo it seems the two 3300uf caps have already been replaced before.
        Start by disconnecting one buffer board at a time and then test if the panel would turn on and you should get half a picture (ie: if you disconnect the top one, only the bottom picture will show and vice versa). However I wouldn't leave it on long like that, I've seen the good buffer go bad if left on too long.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          Thank you. You just helped me learn something I never knew before. People like you help me out a lot... I have been repairing tvs for 5 months now on my own. Didn't know anything and I plan to open a tv repair shop. And I'm learning as I go. Hopefully a yr from now. Ill be ready. I can fix a lcd no problem. But man I'm scared of plasmas
          • mattstolte
            • Dec 2013
            • 612
            • usa
            so now I disconnected buffers one at a time and nothing, the tv used to go from stand by to on and fans kick on for a sec and click off, now it wont even goto on, just stays in standby
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
            • Jack828
              Hitachi 42HXT12U - Not working - Standby LED Flashes
              by Jack828
              Hello fellow tech geeks!
              I've recently come into possession (a freebie!) of a Hitachi 42HXT12U LED TV which does not work.
              It does the following:
              - Plug in
              - Standby LED flashes alternating RED and BLUE approx 6-7 times
              - Does this approx twice
              - Standby LED stays solid BLUE
              I've opened it up and had a look at the PSU board (which is a 17IPS20 23145828) for any bulging caps and there aren't any.
              Any ideas folks? If you suggest replacing the PSU board then I'll go ahead and do it - only about 30 quid off...
              12-13-2020, 09:14 AM
            • Crystaleyes
              Samsung BN44-00259A standby question
              by Crystaleyes
              Hi all.
              I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
              SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
              Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
              The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
              08-11-2023, 05:15 AM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
