samsung 50 inch plasma colours mad
  • adamp91gvm
    • Jan 2014
    • 706
    Re: samsung 50 inch plasma colours mad
    You are correct the av board is goosed tried one off another 50 plasma and it come on perfect it just don't fit in the back casing so i can not use it
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
    • porfyriadhs
      Samsung Plasma PS51D6900DS Bootloop
      by porfyriadhs
      Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
      Thanks a lot !!
      10-19-2023, 11:31 AM
    • ArMaaN376
      Samsung PS51E550 Plasma TV
      by ArMaaN376
      I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
      Opened TV cover & observed foll
      a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
      b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
      c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
      How to confirm Y -Buffer board...
      06-19-2024, 04:05 AM
    • CDNBrewer
      Samsung Plasma PN43D450A2D No Power
      by CDNBrewer
      Hello, I have a Samsung Plasma TV - Model # PN43D450A2D
      This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
      I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
      When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button...
      03-02-2025, 04:59 PM
    • alltvrepairs
      Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
      by alltvrepairs
      I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
      I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
      Any one met this problem in the past?...
      10-08-2025, 07:34 AM
