Samsung PN50550T Won't Turn On!
    Re: Samsung PN50550T Won't Turn On!
    Check the Vs & Va voltages from the power board. I am not yet sure if the control board is bad or not yet. Need to check a few other things first.
    • coppercitycomputer
      • Apr 2014
      • 90
      VA nerver go's above about a volt and a half sometimes northing, VS makes it almost to 5v then drops down. All while the relays are clicking.
        • Apr 2014
        • 90
        Whats the next step on this?
          Unplug the X- and Y-main boards and see if Vs will rise with them out.
            • Apr 2014
            • 90
            VG makes it to about 15V, VS makes it to about 5V then the PS shuts down.
            What's next?
              • Apr 2014
              • 90
              With the controller unplugged from the PS but with the X and Y, the VG is a steady 15V the VS very slowly raise's! and slows down around 8 volts. I also hear chimes when plugging in and trying to turn on.
              Next step..
              Thanks for all the help so far!
                It seems like the power board might be at fault. Can you provide a complete picture of it?
                  • Apr 2014
                  • 90
                  Ok as asked here is a photo!
                  Thanks, next step?
                    OK, with TV power OFF and UNPLUGGED, test this fuse.
                    To test use the 2000 ohm range or continuity range of your multimeter, place probes across the fuse and note the fuse's resistance.
                      • Apr 2014
                      • 90
                      Wide open 000 on the 2000 setting.
                      Next step?
                        You mean short?
                        Show me which connectors you're pulling for isolating X- and Y-main boards so I can be sure...
                          • Apr 2014
                          • 90
                          Yes that fuse is shorted, same way if you touch the leads togother. Those are the wires I have been testing the voltage's from and isolating X and Y boards. Tested again to confirm wide open 0000.
                          Next step?
                            OK, so now unplug the main board connector and leave only your resistors and ground wire in the 6 pin connector going to the control board. Only the power board connected to this connector, leave control board disconnected.
                              • Apr 2014
                              • 90
                              Ok I am a bit lost on this one. Could you rephrase?
                                • Apr 2014
                                • 90
                                If i unplug the controller, with the 100 Ohm resistor shorted from VS-On to 5.3V the set trys to start when I push the power button. It clicks a few diff ways, waits to start the screen then click offs. No chimes or anything can be heard.
                                Edit:: With the resistor in the harness from VS-ON to 5.3V and leave it connected to the controller but unplugged from the power supply, the set makes the chime and trys and waits for the screen to come up.
                                  Controller = control board, right?
                                  In the first test the main board is unhooked?
                                    I want you to test as before with the jumpers in the 6 pin, but the main board's larger connector should be removed.
                                      • Apr 2014
                                      • 90
                                      The main board I ausume you mean the input board? If I unplug that from the power board (large black wire harness) with the controller unplugged from the power board as well northing happens. No clicks no life.
                                        And that's with the resistors/wire installed to force the PSON VSON lines?
                                          • Apr 2014
                                          • 90
                                          Yes! VS-On 100Ohm to 5.3V and PS-On to ground.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
