Samsung UN55B8000F Mainboard Issue(Relay Clicking Issue)-Help!!
  • ALR
    • Nov 2012
    • 111
    Re: Samsung UN55B8000F Mainboard Issue(Relay Clicking Issue)-Help!!
    Yes...I gave up on trying to troubleshoot issue and found a board on Ebay for $100 and snagged it up. Working great now..
    • jfarmer
      • Jul 2014
      Power board or control board?
      • ALR
        • Nov 2012
        • 111
        Yeah, I swapped out the mainboard. Was very hard to find one and when I did, it was almost 300 bucks. Found one for $100 on ebay!
        • Louis82
          • Feb 2012
          • 240
          Hey guys. I sen this main board to PTS to have it repair and tv is now working. Found that parts they replaced on it are: IC203 and IC503. The description on IC503 is IDT6V100-12PGG. Do you guys know what this IC does? I been looking for specs but can't really find much info.
          Thanks and Hope soon we can get the fix for this board as this is becoming almost impossible to find a replacement.
            09-07-2024, 05:50 AM
          • alltvrepairs
            Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
            by alltvrepairs
            I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
            This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
            Any help appreciated!...
            03-14-2024, 03:39 AM
          • vincentedel
            Samsung SyncMaster 740n Phase Control Issue
            by vincentedel
            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
            04-22-2025, 12:33 AM
          • Manucsl
            QE65Q800TATXXC Samsung TV Issue
            by Manucsl
            Hello.
            My TV is a QE65Q800TATXXC Samsung TV.
            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
            Any ideas to check would be very appreciated 😊
            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
            02-19-2025, 07:47 AM
          • FourRunner
            Display issue Samsung TV UA65JS9000W
            by FourRunner
            I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
            10-03-2024, 07:05 PM
