Installed new x-main for Insignia NS-51P680A12. Do I have to update firmware for new board?? How do I do that??TV works but don't want to screw it up. The no power ,clicking ,standby light only problem was x-main. A lot of posts for Samsung plasmas have been the same. My TV is basically a Samsung so if psu checks out go to x next .
Updating firmware on new board??
Re: Updating firmware on new board??
There is for some Samsung TV models but you'd have to contact whoever makes insignia to find out. Won't be surprised if there is no firmware support for it.Installed new x-main for Insignia NS-51P680A12. Do I have to update firmware for new board?? How do I do that??TV works but don't want to screw it up. The no power ,clicking ,standby light only problem was x-main. A lot of posts for Samsung plasmas have been the same. My TV is basically a Samsung so if psu checks out go to x next .Last edited by tw2005; 03-28-2014, 12:01 AM. -
http://www.insigniaproducts.com/prod...upportTab=open
I don't see anything, maybe send an emailComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by H34TORecently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...06-17-2025, 07:17 AM
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by rookiemeHello,
I'm searching for a usb firmware for the notebook of the title.
The issue is that it stays at 5V only input from both usb c ports and the controller TPS65994 has been replaced.
The firmware should be the U5502 and I upload the dump of it.
Lenovo provides firmware updates but I was unable to find the appropriate file inside.
s/n: PF33180Q
Thank you....-
Channel: BIOS Requests ONLY!
- Loading...
