panasonic TH-32C4M
  • willyam1
    • Feb 2012
    • 112
    • israel
    panasonic TH-32C4M
    HI.
    no pic in hdmi and pc inputs but in component input its ok.
    osd ok.
    can factory reset procces can help it? and how to reset it? thanks willyam
  • Oliver Kocsis
    Panasonic FZ-G1AD-001M bios password reset
    by Oliver Kocsis
    Hello. Can you please help me with removing the bios password from my Panasonic Toughpad?
    04-22-2024, 09:21 AM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
  • odie34
    Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
    by odie34
    I am a hobbyist (not a professional) so please be gentle...
    I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
    I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
    02-18-2024, 09:11 AM
  • ictc
    Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
    by ictc
    I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
    Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
    The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
    02-25-2025, 12:15 PM
  • kotel studios
    ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
    by kotel studios
    Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
    Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
    I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
    12-14-2024, 10:48 AM
