Westinghouse SK-19H210S
  • n3lka
    • Jan 2014
    • 84
    I came across a Westinghouse SK-19H210S with a PS problem. Fixed it, but I can't get it to scan for Digital Channels. When performing a channel scan, it scans analog only, and then goes to the DTV screen, and just sits there.
    I looked through the manual, not that that provides any good information. I emailed westinghouse, but maybe someone out here has played with it.
    Does anyone else have this TV and have had any luck with it in DTV?
    Other than that, it's a nice little set, AV inputs work fine on it.
  • alro7779
    Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
    by alro7779
    Hello, guys!
    I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
    Alex....
    10-03-2025, 05:49 PM
    MS-15851 HD Motherboard Scans
    by SMDFlea
    MS-15851 HD Motherboard Scans .Credit to Doc! at comsystem-tlt for these...
    01-26-2025, 05:50 AM
  • Nicktronic
    Westinghouse W55UW4620 No Video
    by Nicktronic
    Ok, so I know I know, it's a Westinghouse....lol It's got the backlights but no video. Likely the panel, but I'd like to take some measurements on the buffer board with help from you experts to confirm. See the attached pictures. In pic #1, there's a nice pin reference to use to take some measurements. The large IC in pic #7 gets up to 60degC when the TV is on.
    So, backlights, no video, go! 🙂...
    06-03-2024, 03:21 PM
  • EBW
    Help Request - Westinghouse 32" Smart TV (Model: WD32HBR105)
    by EBW
    Westinghouse 32" Smart TV (Model: WD32HBR105) . Originally stuck on logo with no response from remote and no firmware file available to flash via USB. Westinghouse Support stated it would require service but that wasn't a cost effective option. I used dental floss to remove the motherboard processor heatsink to identify what make it was (Mstar). Unfortunately that knowledge didn't help with a solution. After the heatsink removal it only displayed a completely white screen. I then decided to replace the motherboard with a universal 3-in-1 board but the white screen problem continued. This...
    10-27-2022, 06:32 PM
  • Seville
    Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
    by Seville
    Hello all!
    Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
    I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
    10-10-2022, 07:31 AM
