Panasonic TC-P50G25 10 blinking light failure.
  • NJRoadfan
    • Sep 2014
    • 15
    Re: Panasonic TC-P50G25 10 blinking light failure.
    Just for the heck of it, I tried turning on the TV again last night. The error code isn't consistent this time around, I get 4 blinks or 10 blinks. I'll get around to diagnosing it this weekend, at least it isn't hanging up on a wall.
    • tw2005
      • Oct 2011
      • 6458
      Both of those are common shorted SC codes. The 4 blink generally means the PSU is shorted and most likely be Vsus low resistance on SC2
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        #43
        An important thing--Not to do, is keep trying to power the set up with a faulty SC.
        --especially if you have confirmed its faulty by a simple test of Q661
        Any 4/10 blinker Panasonic--Don't bother with all that nonsense in the service-manual--First check Q661, don't even have to remove a single wire, plug or the board from the chassis,--and no extra powering up of the set.
        Can nearly guarantee, it'll be short. When an SC board goes--Always IME, Q661 dies....
        (It may even be the root cause of the problems, failing--then killing everything else...)
        --If you intend to repair the SC, repeated powering can well cause more damage to an already damaged board making the repair both more time-consuming and more parts needed, and with less chance of success for a first-timer....
        TELEFIX
        • riparo
          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
          by riparo
          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
          I attach a link to download the service manual, thank you for anyone who can help me
          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
          01-11-2024, 12:35 PM
        • Andre Gilbert
          by Andre Gilbert
          11-20-2024, 08:52 PM
        • ItepK
          Panasonic TX-P42G30E green light blinking, no video, no audio
          by ItepK
          Hey everyone!
          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
          This post describes my entire troubleshooting process of this TV.
          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
          I've taken the unit apart, and I've started to check some voltages:
          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
          12-22-2023, 05:06 AM
        • Tof
          Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
          by Tof
          Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
          When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
          The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
          I opened it and found a burned connector on PB-board on the 24V pins.
          The 24V wires have change a bit of color due to the overheat and the corresponding...
          02-01-2022, 03:18 PM
        • itachi
          Panasonic TC-50AS630 No Image - Blinking LED
          by itachi
          Hello good people, I have another unit here which is giving me problems. Upon plugging the unit it, after a few seconds the front LED will start blinking 3 times in a row and repeating indefinitely. No image or sound.
          The first thing I checked was the backlight. It's a single vertical strip on one side of the panel which has 8 groups of 7 LEDs. (Part #V500D2-LS1-TREM3) I used a backlight tester and each group lit up without issue.
          The standby 5.3V is good, the 16V and 24V from the PSU board both come up for a few seconds while the TV_SUB_ON signal is high. Both 16V and...
          01-05-2021, 12:12 AM
