I just picked up This 50" Samsung Plasma TV from my brother-in-law, thinking that it would be a simple repair. After reading several threads, and doing a lot of research, I'm lead to believe it could be one of 3 things (or sadly a bad panel): a loose ribbon cable, Y (why not X, since the lines are spaced along the x-axis?) Buffer Board, or the Timing Control board. The vertical lines are only 1 pixel wide and are randomly spaced out, but only on the right half of the screen. They consist of magenta, cyan, and green. Would anyone have any ideas, or be able to provide a little more insight to narrow it down to one of these replacements?
PN50A450P1D Thin(1 pixel wide), colored vertical lines - only right half of screen
Re: PN50A450P1D Thin(1 pixel wide), colored vertical lines - only right half of scree
Almost certainly a bad panel if they are randomly spread out, this is a common issue with this model of Samsung plasma.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
I mean the plasma display panel itself has failed, more specifically the bonded chips at the bottom of the panel, unfortunately this will not be economic to fix in most cases as a new screen will exceed the value of the TV.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Newbie here.
If the same type of symptom (thin vertical "noisy?" Colored lines) were to be evenly bad across the whole screen, would that also indicate a bad panel? (failed, imbedded chips at the bottom?)Comment
by rfxcaseyI have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
05-16-2024, 06:52 AM -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by rapid911Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
by GjacksonHi, I have a sort of old Grundig LCD Led TV that starts to display black horizontal lines after some use. After it's been turned off for a while and cold it does not display any artifacts however after some use it starts to display some faint horizontal lines at the top of the screen and a bunch in the middle of the screen. The longer the tv is on the worse they get until they become very clearly visible. I suspect that heat has something to do with this as when the lines start to appear i notice that the tv's metal case has gotten warm. Could the T-CON start to malfunction when it starts to get...01-31-2022, 02:25 PM
- Loading...
