smd code 431
  • chetreynolds
    chet
    • Aug 2010
    • 77
    smd code 431
    I have a model dps-475ap power supply from a vizio tv > It has several smd sot 23 devices marked 431h my code book lists it as a zener diode . But my compenent tester indicates that it is an npn transistor with non typical pin out outs ebc base the top single pin . It is also marked as ic... on the board other transistors are labelet q... and diodes are labeled d...
    Any sugestions on how to identify this device?
    Re: smd code 431
    Probably a TL431? Voltage reference, adjustable zener diode.
    • chetreynolds
      chet
      • Aug 2010
      • 77
      Re: smd code 431
      Not likely the board has at least 10 of the devices and it is to small for any power smd sot23 package . Thanks for the response
      • tw2005
        • Oct 2011
        • 6458
        Re: smd code 431
        Really
        I found the following from a DPS-250 drawing.
        APL431HAAI-TRL (ANPEC)
        TLV431ASN1T1G (on-semi)
        Available as SOT-23, SOT-23-5, SOT-89, SO-8, TO-92, TO-92S etc
          Re: smd code 431
          What is the TV not doing?
          Is this the model you have?
          http://s807.photobucket.com/user/bud...?sort=3&page=1
          http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
          • klynstronic
            Regulatory code marked as H50A
            by klynstronic
            Hello. Does anyone know the code for this regulator marked H50A A121?​...
            04-23-2025, 11:08 AM
          • klynstronic
            Help to identify the component code marked as .11.
            by klynstronic
            Hello. Could you help me identify the code for this component marked .11?
            It belongs to the BMW X1 automotive gear selector circuit.​...
            04-18-2025, 10:24 AM
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • Dvsr
            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
            by Dvsr
            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
            After replacing the caps I started testing out the speaker. It seemed...
            09-10-2025, 10:20 AM
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
