samsung LE19R88BD
    Re: samsung LE19R88BD
    Putting new EEPROM in would be only way to find out I guess if the main board has another fault.
    • tonyuk
      • Feb 2014
      • 238
      • uk
      ok will do that also got a new heat station atten 858d+ works great tried today for buffers remove was loads better just wating for my new solder iron with lcd heat temp on that solder and solder wick come aswell that allso alot better
      • tonyuk
        • Feb 2014
        • 238
        • uk
        ok so fitted another eepsom chip today and just get the pink with green lines still ? any help plz
          Would suggest testing voltage regulators. If not, I would suspect main board is faulty, but probably not worth replacing for 19" TV.
          • tonyuk
            • Feb 2014
            • 238
            • uk
            ok think il leave as like you said not worth it just thought would be gd to learn on lol
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #26
              im sure ive had a fault like this on a goodmans set same sort of picture fault mine was the board thats bonded to the lcd screen i suppose its like a tcon board where the wires go from the main board to it there was a bad connection it worked when any pressure was put onto that area so in the end i tapped it dowm it was fine after that.
                09-07-2024, 05:50 AM
              • Robby-Gr
                TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                by Robby-Gr
                I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                Additional issues:...
                09-27-2025, 12:02 AM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
                LCD LED TV Service Menu Codes
                TCL LED TV Service Menu Code
                LG LED TV Service Menu Code
                10-31-2024, 03:58 AM
                09-06-2024, 11:40 PM
