Panasonic TH-46PZ80U plasma 7 blinking lights
  • Zelek11
    • Feb 2014
    • 5
    Please help me diagnose the problem with my Panasonic plasma TH-46PZ80U. I don't have any equipment to test the TV and I'm trying to decide if it's worth buying some used parts on ebay to try and fix it.
    I got the 7 red blinking lights of death. I was able to "fix" the TV by detaching the ribbon cable from the SC board. I would then power on the TV and the blinking lights are gone. I would then reconnect the ribbon cable and be able to watch TV for anywhere from 1 day to 1 week before I would have to repeat this procedure.
    Given this information, what part(s) most likely need to be replaced?
    Re: Panasonic TH-46PZ80U plasma 7 blinking lights
    it sounds like either an SC board or D board fault. These boards are pretty cheap because they rarely fail. One of the things you should first do is check the SC board cable is seated on both ends - it goes under the A board and connects to the D board.
    If that is good, you will need a multimeter. There is a point marked TP_SOS7 on the SC board. You can check the voltage here. If the SC is bad, when the set shuts down it will spike up to 2V or more. If it doesn't, then it's more likely a D board fault (the SC isn't completely eliminated but is much less likely.)
    • bialag
      Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
      by bialag
      I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
      Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
      03-25-2025, 05:56 PM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      I happened several times, in the search for help from the web, to consult this very interesting forum.
      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
      Having said that I come to the gist of my post on the forum as the title suggests.
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • Eaglecrest
      Panasonic plasma color stripe
      by Eaglecrest
      I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
      11-05-2025, 06:16 PM
