It's a plasma ps50b451b2wxxu it had a line down the screen but I have got it back on as u can see on the pics it's like a image burn any idea how to get rid of it also the v scan is up and down I have checked vs and va and there spot on
samsung 50 inch plasma
Tags: None
Re: samsung 50 inch plasma
I'd look at that Vscan part closely, try adjusting it, if that is bad, this very effect can sometimes be observed.
What does Vscan measure?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Well that's no good at all then. Pic of Y-main?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Can you get a closer shot around that yellow transformer? Top left of board from your pic.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Last edited by tom66; 03-02-2014, 02:50 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Out of the top rod as u look at it 205v next down 15.4v and the lowest nothinComment
What?
Test Vsch to ground, then Vsch to Vsc. Only test those two. Also part # of highlighted device - not pin voltages for now...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can't read that part #, please read it off.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by porfyriadhsHello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
Thanks a lot !! -
by ArMaaN376Hello,
I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
Opened TV cover & observed foll
a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
How to confirm Y -Buffer board... -
by CDNBrewerHello, I have a Samsung Plasma TV - Model # PN43D450A2D
This was my parents TV and the initial symptoms were that the display was hard to turn on with the display making various clicking noises until one day it would not turn on anymore.
I took a look and found a couple 1000uF capacitors (i believe on the low voltage size) that had leaked out their electrolyte and did not test well on a tester. I replaced them but still no dice.
When the TV is plugged in, there is no clicking, LED status lights (on PCB boards or the front display) and the power on button... -
by chazhThis is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,... - Loading...
