I don't about this one looks like a bad panel for $100.00 I don't think it is worth working on . Could sell the boards but I don't see much demand for them. Would using thermal pad on the tab bonds help this. I just don't need a boat anchor.
Sony kdl-52xbr5
Tags: None
Re: Sony kdl-52xbr5
Yep that's tab bond failure. Its 50/50. Sometimes it is a success sometimes not. Certainly worth a shot. Its an xbr5. Its a popular setDid I leave the soldering iron on? -
Re: Sony kdl-52xbr5
I have had good luck with tab bonds. I have a 46-xbr5 fixed the tab bonds almost two years ago and no problem yet. I'm going to call the guy and pick it up. Thanks for the knowledge it means a lot getting a second even third opinion before buying. Thanks Again.Comment
Re: Sony kdl-52xbr5
I talked them down to $50.00 going to get it today. I Will post pictures of the tab bond fix.Comment
Re: Sony kdl-52xbr5
or 52xbr5 ? These sets take some time to fix (at a cost of 10 cents !). I have repaired 3 of them now. If you're persistent - they are fixable. The key is to fiddle and get the ribbon cable in the right place and stabilized. seems like its always the top left buffer. If u think its the tcon board - its not.Comment
Re: Sony kdl-52xbr5
I have a service manual but it's in an *mht format that I can't post as an attachment. If you PM me I can e-mail it to you. Got to say though, I didn't find it very useful. About the best thing I got out of it was the fault codes.Comment
Re: Sony kdl-52xbr5
A training manual attached. There's also a service manual at Tom's Manuals for anyone trying to track one down.Comment
Re: Sony kdl-52xbr5
Can't find the pics of the Sony , but here are some of a Samsung I did. Did them both the same way with thermal pad. I do tab bonds with the tv standing up with just the bottom screws holding the frame on. That way I can try over and over until I get the sweet spot that keeps the picture sharp and clear.Comment
Re: Sony kdl-52xbr5
Can't find the pics of the Sony tab bonds , but here are some of a Samsung I did. I do the tab bonds with the set standing with only the bottom screws holding the frame. I found doing it that way I can check with the frame on the picture over and over with no chance of the glass panel moving , and getting broken.Comment
Re: Sony kdl-52xbr5
I'm 99% sure it was a LN52A850 with ghosting problems. I do a lot of tab bonds . 4 out of 5 get fixed only because of the thread about thermal pads for the fix. I used to use the little plastic bumpers , but it was a 4 out of 5 failure rate. Standing up is so easy compared to lying panel down can watch the picture as you try different points on the tabs. No chance of the panel sliding off to take a look at the screen.Comment
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...09-06-2024, 05:30 AM
This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...09-06-2024, 05:27 AM
- Loading...
