LED panel type for QE75Q60RAT
  • marekk
    • Mar 2013
    • 36
    I'm trying to repair 75" QE75Q60RAT with a faulty main AV board after a lightning strike.
    I got a main board for 55" QE55RU8000 which works in this TV but the picture is bright with very low contrast.
    In the service manu I have changed LED panel type to 75" 75L1AU0NR but that didn't help, unfortunately.
    Could you let me know which panel type is in the service menu for this model?
    TV is based on CY-RR075FGHV1H
    I would be very grateful
    Best regards
    Marek
  • lotas
    • Jan 2016
    • 4845
    • Russia
    Here you need to carefully compare the boards, there are positional resistors (they can be set to different panel diagonals) and you need to rearrange the spi flash 25Q80 from your native motherboard, this flash T-CON, it contains all the settings for your panel...
    • Diah
      • Feb 2013
      • 6553
      i would forget QE75Q60RAT .. and setting it at service menu as 75RU8000 .. panel sizes deferment will be at LVDS depth
      • marekk
        • Mar 2013
        • 36
        Thank you will try that, in the past I have successfully moved screens (glass only) between 55RU8000 and 55Q60rat so I know that either mainboard can work with this panel but now the sizes of the panels are different.
        • marekk
          • Mar 2013
          • 36
          Indeed I have found many differences between those mainboards.
          Unfortunately, after I changed several resistors, removed one DC/DC regulator swapped 25Q80 flash, board works worse than before.
          TV does power cycle with backlight only, no even logo displayed.
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
          • vf fa
            EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
            by vf fa
            Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
            I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
            So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
            01-31-2024, 01:40 PM
          • electronx
            Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
            by electronx
            I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
            1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
            According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
            If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
            06-26-2025, 03:27 AM
          • Robby-Gr
            TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
            by Robby-Gr
            I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
            However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
            The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
            Additional issues:...
            09-27-2025, 12:02 AM
          • Daveleone
            Proscan PDLED3992A firmware or service menu panel type
            by Daveleone
            Hi all!
            I got this PDLED3992A TV for free locally. No standby light. Would not power on. It has a single board inside that controls everything. I bought a replacement off of eBay, but the seller sent me the wrong part (my board is A13082443, they sent A13072083). The LED header for the board was in the wrong position. The seller refunded my money, so I decided to try to take the LED header off my old board and put it on this new board. Well, the TV powers up, but it looks like this board is configured for the wrong panel type (I looked up the part number and this board is designed...
            10-13-2018, 12:33 PM
