Samsung ps50a457
  • sordids999
    • May 2013
    • 2161
    Samsung ps50a457
    Ok so ive got this tv which was totally dead so i checked on the net for any symptons so found this site and basically removed all the parts they listed and tested,but i could not find nothing wrong so i put the power unit back on noticed a standby light was on and the tv works now.
    so could it have been a cold joints etc ?
    thanks
    Re: Samsung ps50a457
    Check all connectors seated and burn the unit in for a few days maybe on control board test patterns (auto gen using the jumper on pins 3-4.)
    • sordids999
      • May 2013
      • 2161
      typical ran all last night and this afternoon but just went into standby
        Well if they were all that easy.....
        Start by taking pictures of the boards. Sounds a lot like a main board fault.
        • sordids999
          • May 2013
          • 2161
          so when i first had the tv it had no power it was totally dead
            So, what's the fault -now-? Do you have any 5V standby from PSU?
            • sordids999
              • May 2013
              • 2161
              hi tom all i basically done was tested the following parts listed below due to the tv was totally dead (but did not test the mosfet )
              F801S
              BP802S
              DP081
              CP085
              CP086
              FM801S
              FB801S
              DQ801
              DQ802
              DB801
              DB802
              DB803
              http://www.ohmsupplies.co.uk/Repair-...50A456-P50A457
              tv came back to life after doing this ran for a few hours last night but today went into standby ill be home later to test the 5v standby
              • sordids999
                • May 2013
                • 2161
                5v standby is 5.07 volts
                  Any standby indicator? Unplug set and plug it in again - any flashes from light?
                  • sordids999
                    • May 2013
                    • 2161
                    No tom
                    • tw2005
                      • Oct 2011
                      • 6458
                      Sounds like it could be dry joints. In the picture I thought Q801 looked a bit sus but it is blurred. PSU looks similar to the 50Q91,96 which I had one with similar issue. Cracked joints on the FETs.
                      I'm assuming you have 5v standby the whole time.
                      • sordids999
                        • May 2013
                        • 2161
                        Yes 5v standby constant I have since resoldered the MOSFET joints all working again at the moment
                        • tw2005
                          • Oct 2011
                          • 6458
                          When I discovered this issue I found when I flexed the board mid point I could get the TV to fault and just shutdown. hopefully this is all it was, no doubt we'll find out in time.
                          • sordids999
                            • May 2013
                            • 2161
                            Still working today so keeping my fingers crossed
                            • tw2005
                              • Oct 2011
                              • 6458
                              Did you see any obvious bad joints? intermittent faults are always fun, hope the luck continues.
                              • sordids999
                                • May 2013
                                • 2161
                                Not really resoldered Q801 and Q802 still waiting for it to go into standby though
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Can be hard to tell, but everytime you touched the board it came back mysteriously. I would have gone feral and touched up all the heatsinked parts to totally take that out of the equation but where those are that is the equivalent heatsink and FETs that gave me grief.
                                  Nil cost and a bit of time, better than replacing boards straight away. I guess once it starts running longer than it has previously then our confidence will grow.
                                  That one I had could run for hours, be good for a few days then just randomly drop dead but was perfect when it was going. Took me a week to get it to fault, that's when I thought I'd try and induce it with tapping the heatsinks.
                                  Once I flexed the board that permanently made it worse, it was fun. Was a fix for a mate.
                                  he just put up with it . i have seen one go up in smoke though with those bad joints.
                                  • flocko
                                    • Nov 2012
                                    • 1121
                                    when it fails do you have the relays clicking when you power on? i have had two with relays with dry joints on the back of the board
                                    • sordids999
                                      • May 2013
                                      • 2161
                                      I have a loud relay clicking when I turn it on anyway then it chimes and turns on
                                      • Maroboy
                                        • Feb 2014
                                        • united states america
                                        Im new to the site hi
                                          09-07-2024, 05:50 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                          09-06-2024, 11:40 PM
