Samsung ps50a457
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Samsung ps50a457
    You said in the beginning that it was totally dead ?
    • sordids999
      • May 2013
      • 2161
      • uk
      Yes flocko
      • flocko
        • Nov 2012
        • 1121
        • uk
        did you have stand by light or not?
        • sordids999
          • May 2013
          • 2161
          • uk
          No flocko was totally dead
          • flocko
            • Nov 2012
            • 1121
            • uk
            so good place to start would be 5v standby transformer and all that fires that up the viper chip and diodes there should be a download for this power board on here
            • sordids999
              • May 2013
              • 2161
              • uk
              #26
              Any pointers on this flocko and see if I can beat my five pages record
                Yep, check for BN44-######[A-Z] number and search my site or the wider internet and you should find it.
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  #28
                  so were are you now is the set running with an intermittent fault, you my be looking to hard for the a lot of problems can be fixed on these BN44-00205A with some good old new caps and if you are keeping it then swop them out anyway , dont forgetthe 3.3/33 /47/220uF 50v ones on the hot side when you change them as these control the relays when it powers up flocko
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    #29
                    Hi flocko no the set is running fine at the moment so I'll change those caps like you said, what's the best caps to use ?
                      Would use Panasonic FM, FR or FC... You can get then from CPC. For capacitance (uF) below about 22uF use Panasonic M or NHG series.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #31
                        Yes i have to side with Tom with the panasonic caps , how did you get the Regulators off the other board cut and clean like i said ? when you put the new ones on tack one leg make sure its on the pads Ok then do the rest Flocko
                        • sordids999
                          • May 2013
                          • 2161
                          • uk
                          #32
                          Hi flocko yes I cut the legs like u said and removed the regulators it was not easy for my first attempt,one pad slightly lifted but should be ok waiting for the parts now so fingers crossed
                          • tw2005
                            • Oct 2011
                            • 6458
                            @ Flocko / Tom. Now my head is hurting trying to understand what's what.
                            Posts 8 thru 12.
                            #8 5V stdby = 5.07
                            #10 nil stdby LED indication, nil flashes
                            #12 5v stdby constant.
                            Is it possible to have the 5V but nil stdby LED lit?
                            Weird. Or is it recovering? If 5v stdby was lost whilst the TV was running would it just shutdown?
                              Most Samsung TVs turn off led when set is running. Could also be bad main board - typically standby micom will be responsible for that led...
                              • sordids999
                                • May 2013
                                • 2161
                                • uk
                                #35
                                @flocko/tom do you think its best to change all caps even the big 450 volt ones or just the 50 volt caps
                                  450V ones are usually OK - but the small ones if they're a known problem I would change them
                                    09-07-2024, 05:50 AM
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • ChristianBr01
                                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                    by ChristianBr01
                                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                    04-23-2025, 01:48 AM
                                  • Kaar3l
                                    Samsung QLED QE65Q7FNAT only standby light
                                    by Kaar3l
                                    TV: Samsung QLED QE65Q7FNAT
                                    PSU: BN4400940A
                                    MB: BN94-12832K
                                    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                    09-24-2024, 01:35 PM
                                    09-06-2024, 11:40 PM
