Signals from control board to PSU on a plasma
  • Ashroyer05
    • Sep 2013
    • 162
    • U.S
    Can a control board or main board send 15V or so to the psu. Or does one of them send a small voltage? On a regulator I am working with pin 1 is input. If I trace it to a connector pin it goes back to a connector from one of the other boards (not the psu). The input voltage for that regulator is 15-40V according to the sheet. I'm trying to figure out why There is not voltage on the regulator or the one next to it. I need to know where the voltage comes from for Vin.
    thanks for any help.
    Re: Signals from control board to PSU on a plasma
    Generally the signals from control board are on the order of 3 to 5V.
    Input voltage like that is probably related to a power supply voltage like 15V or 24V.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      PSU will often receive a Vs-on and Va-on signal as well as sometimes, a PS-on signal from the control-board.
      Still others will have a 3.3v-on and 12v-on too....
      Some make sets however the control-board, will 'ground' these pins to bring the PSU active....
      Different makes, different ideas, advice is--Look for a Change of State of these control-lines when activating the stby/on switch....
      In Stby--often there's Only a 5V or a single supply of some voltage or other, going to the mainboard, and all other supplies are off--Until the mainboard (Or control board) Tells the PSU to fire up.....
      TELEFIX
      • Ashroyer05
        • Sep 2013
        • 162
        • U.S
        Thanks guys. This board is different. It has constant 3.3 V and weird voltages other places. 6 Volts appears when I fire it up but I think those voltages are supposed to be higher because they start high for a split second and then drop to 6. I traced the input voltage pins from the regulators all the way to where the control boards connect. If the pin requires 15-14 V to run and the pins go to the control boards does that only state the obvious or am I missing something big? Maybe I have a massive short somewhere?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Well---
          Be a GREAT idea.....
          To TELL us, and SHOW us with a Picture--Just WHAT set it is!!!
          TELEFIX
          • Ashroyer05
            • Sep 2013
            • 162
            • U.S
            I have a few posts on this tv. I figured most would see them since i'm popping them up left and right. This link probably gives the most info in one of my comments towards the bottom: https://www.badcaps.net/forum/showthread.php?t=35401
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Hmm--Still doesnt give the Model-Number Or the Make/Model of Plasma Panel used in your 'Hitachi' set!
              It would appear you are going about this the wrong way--I suspect a Ysus/Xsus fault and the Mainboard is shutting the set down--and Not a PSU fault....
              It would also be a good idea to have just One Thread dedicated to your set/make/model/fault--
              Just posting randomly about different parts on different threads just confuses others and clutters the forum up, with little info passed either way!
              TELEFIX
              • tw2005
                • Oct 2011
                • 6458
                The model is in that post.
                I suspect
                Tv = CMP4121HDU-511,
                PSU = HA00991 (1C81531)
                PDP = FPF42C128128UB-51
                Not sure how accurate the manuals are, might give you some idea.
                SJ search showing other boards.
                http://www.shopjimmy.com/catalogsear...CMP4121HDU-511
                • Ashroyer05
                  • Sep 2013
                  • 162
                  • U.S
                  Thank you for clarifying tw. Almost felt shot down for trying to be descriptive. I appreciate the links too i have been searching for months. As far as sustain board i ptlugged them in one at a time and no luck.
                  • Ashroyer05
                    • Sep 2013
                    • 162
                    • U.S
                    Is it a bad idea to force the inputs high on the regulators to see if they produce an output?
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Have you tried running the PSU without the set, by taking the control-pins high/low as needed to fire it up?
                      That's what I do with dodgy PSUs.....
                      That would confirm whether the PSU --or the set--is faulty...
                      I still think that there's a fault Outside the PSU causing this--disconnecting the Vs/Va from Z-SUS/Y-SUS supplies wont always prove anything, as the set will shut down with these disconnected anyway!
                      TELEFIX
                      • Ashroyer05
                        • Sep 2013
                        • 162
                        • U.S
                        Alastair, I'm not ruling your philosophy out at all. Just have a gut feeling it's the psu. I had some shaky readings from some pins. One pin hits 19,12 V for a split second and then sits at about 6V. And I believe that is an input pin for one of the regulators, but it's coming from the control boards. I would LOVE to force the psu on but there are NO indications of what pin is what that's why I have been tracing pins but the voltages I have confirmed are confusing me.
                        • Ashroyer05
                          • Sep 2013
                          • 162
                          • U.S
                          I DO remember at one point not having one of the ribbon cables attached from the psu to the logic board but the logic board was still connected to psu via a wire connector. At that point the Green LED on the tv would come on and stay on. The screen still was not powering on but the led stayed lit. Now the tv would not turn off at that point but I suspect that's because the logic board did not have full control because of the ribbon cables being disconnected. Is this maybe a sign that it is NOT a fault in the power supply?
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • Yanleb
                            LG 60PK550 Logic Control Board EBR63450301
                            by Yanleb
                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                            C57: 3.30V
                            C61:...
                            07-20-2023, 12:38 AM
                            Linear Garage Door Opener Control board took a crap install a new control board back normal
                            I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                            02-08-2025, 06:52 AM
                          • redoxy
                            Control Board Replacement for 2K display
                            by redoxy
                            I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
                            The display is Samsung LTM270DL07.
                            I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
                            I am looking for inputs on what board could potentially be used for my display.
                            Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
                            Also attached is a technical...
                            03-14-2023, 08:52 PM
