Lg 50pc56
  • sai2006
    • Feb 2014
    Lg 50pc56
    Hi
    I have a 50 inch lg television. when i go to turn the tv on i hear a click at the back the light goes from red to green and it will flash 4 times and then it will go back to red. The fan also dosent seem to be working as well.
    This is what i have tried so far: I have disconnected all the connectors going from power board to the main board and the ysus board. When i turned the tv on the power board just kept on clicking away without anything connected to it, i then 1 by 1 connected the ysus board and the main board and it still the same.
    Do you think it could be a power board issue?
    Any help would be very much appreciated. I am new to this so please be patient with me and if you could give me clear instruction then that would great. Thank You.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Lg 50pc56
    What test-equipment and electronic knowledge do you have....?
    TELEFIX
    • sai2006
      • Feb 2014
      Re: Lg 50pc56
      Not much knowledge in electrical. I am familiar with the basic usage with a multimeter. I have just started this as a hobby last month and cant get enough of it. Most of the tvs i have repaired were bad capacitors which were easy to replace. If i could have clear instructions then i would be happy to follow and learn at same time.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • MalodicOne
        Macbook 820-02773 Board short when trackpad connected
        by MalodicOne
        Original fault was customer spilled milk on unit, no corrosion was found on the board. Took mainboard out of original case and LCD and swapped it into the fully functioning case and LCD.
        Shorts show up all over the board when trackpad is connected only. Trackpad is used and fully functioning from another unit of same model. Voltage injection causes trackpad connector to get hot but nothing else, swapped on board connector to rule that out, same issue. Diode reading on IPD_MCU_INT_CONN is higher then reference board @ .935 expected is .803. Shorts show up on PPVBAT_AON_CHGR_REG and...
        03-31-2025, 09:54 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
