OKI LCD TV (XLX190R-4) stuck in pattern test
  • aquiles
    • Feb 2014
    • Spain
    I got a OKI TV which is stuck in a pattern test loop (RGBW horizontal stripes, grey screen, white screen, black screen... and back to RGBW)
    I tried entering to the service menu (menu+9301) in order to deactivate it but isn't working, I cannot get into the service menu.
    Is there any key combination for exiting from the pattern test mode? Or for doing a factory reset?
    Main board: XLX190R-4
    Thanks!
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • B83C
    HP elitebook x360 1040 G5 Stuck at 'Entering setup menu...'
    by B83C
    Received a faulty HP elitebook from my friend that does not boot up properly. The internal display is broken, so the only way to view the display output is via hdmi. However, when booted up the screen get stuck with 'Entering setup menu...' when esc is pressed upon booting. HP logo isn't displayed on bootup, only black screen, but an underscore cursor appear on top left corner of the screen. Has anyone any idea what could be the culprit here? I have flashed both the EC and BIOS flash but to no avail. The serial number is 5CG9377GCT, and below is the original flash content:
    Also the...
    02-03-2025, 08:28 PM
  • Prott
    Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
    by Prott
    Hello fellow Badcappers,
    I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
    I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
    Thank you!
    03-01-2024, 08:23 AM
  • nono34
    Hisense stuck in Colors cycle like test pattern.
    by nono34
    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
    10-24-2024, 04:31 PM
  • YellowJacket
    SHARP LC-32CHF5111K - stuck at color test mode
    by YellowJacket
    Hi friends,
    TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
    So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
    02-04-2023, 03:11 AM
