Discoloration after color wheel changing on Samsung HL-P5085W
  • fikus
    • Feb 2014
    • 10
    Hi.Color Discoloration after color wheel changing on Samsung HL-P5085W.May be i need to do some adjustments?Please see pics attached.
    Thx, Felix.
  • Dang
    • Aug 2013
    • 440
    Re: Discoloration after color wheel changing on Samsung HL-P5085W
    It has to be related to the act of changing the wheel so check every connector, make sure they are all seated properly, it is possible that you gently knocked one while reaching inside to change the wheel, good luck.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Why did you change the wheel in the first place?
      --ie, what fault did the set have?
      Looks like a gamma-correction type fault, dunno, haven't done much with DLP types....
      TELEFIX
        I think on these sets if you change the color wheel you have to adjust the timing on the service menu. Norcal715 on YouTube has a video on it.
        • RON_CET
          • 217
          See attached also pay attention to #9 step
          Ron Driver,BSEE,CET,ISCET,NESDA
          • R_J
            • 9553
            If the color wheel adjustment was off you would not have the flesh tones you have, the face color would be off ie: greenish I've changed a lot of color wheels and the index delay was never off that much. It looks like either connections to the dmd board or the dmd board itself has a problem.
            • fikus
              • Feb 2014
              • 10
              Its blowed up
              • fikus
                • Feb 2014
                • 10
                Thx! Will try tonight
                • fikus
                  • Feb 2014
                  • 10
                  the color whell blowed up.before all was good.
                  • fikus
                    • Feb 2014
                    • 10
                    It helped.Problem fixed.Thank you.
