Problem with SAMSUNG UE75AU8002K BN94-16869A/no start up/
  • vendak
    • Jan 2023
    • 12
    • Česko
    HI
    I have a problem with the lcd turning on after a power outage.
    Panel backlight ok. Voltage main and PS too.
    Response to the remote control is fine.
    The led control flashes.
    Main board Y21 NIKE_BUILT_IN
    CODE:BN41-02844A
    BN94-16869A
    Thanks for the ideas
    Vendak75
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    Pass on opening those zips lol, post using pic or YouTube.
    Does it flash red 2 times and restart?
    • the Benninger
      • Nov 2022
      • 189
      • venezulan
      On Samsung TVs there is an advantage to know if it is the main board, you can disconnect the main board from the powersuply, and then energize the source this should work the backlight, with this you would rule out the main board is in trouble you should change it
      • the Benninger
        • Nov 2022
        • 189
        • venezulan
        On Samsung TVs there is an advantage to know if it is the main board, you can disconnect the main board from the powerboard, and then energize the source this should work the backlight, with this you would rule out the main board is in trouble you should change it
        • EazyBone
          • Jun 2023
          • 1353
          • United states
          This isn't true. This rules out the PSU (led section) and LEDs on a tv. Not the main board. The PSU section going to main board could still be bad, the main board itself, the TCON (usually part of main now) or the panel can be bad.
          Essentially this test can rule out half the PSU and the leds
          • vendak
            • Jan 2023
            • 12
            • Česko
            Ahoj
            Po odpojení základní desky od napájení je podsvícení v pořádku
            Kontrolka bliká -bez restartu bez loga-černá obrazovka
            Po odpojení lvd kabelu od displeje žádná
            změna
            • vendak
              • Jan 2023
              • 12
              • Česko
              Hello
              After disconnecting the motherboard from the power supply, the backlight is fine
              Light flashes - no reboot no logo - black screen
              After disconnecting the lvd cable from the display, none
              change​
              • vendak
                • Jan 2023
                • 12
                • Česko
                Hi
                Photo mainboard
                • EazyBone
                  • Jun 2023
                  • 1353
                  • United states
                  What is the led control flashing? So hit power and the screen just continuously flashes? I just repaired an AU 8000 and my symptoms was..
                  Hit power and backlight flashes repeatedly, no reboot just constant flashing. This was the LEDs had blown.
                  Here's what I did to test. You'll have to figure the best way to do this..
                  I took the power board off, so that it was disconnected from the LED connection. I then hooked the main board up, and grounded the PSU using alligator clips. I plugged it in so that everything was hooked up except for the LEDs and I took a flashlight to the screen. Lo and behold there was picture and sound.
                  Rare it happens that LEDs flash constantly and nothing turns on (not reboot). I guess if this what you mean.
                  If this isn't what you mean, probably no need to do this test.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4460
                    • Italy - Milan
                    Wake up! It needs spi eprom sw...
                      09-07-2024, 05:50 AM
                    • bcstedt
                      Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                      by bcstedt
                      Just starting to crack into this one and wanted to get the ball rolling.
                      At power on (plug in), power light on, relays click, repeat (sometimes)
                      After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                      Removed Y-Main for inspection and testing
                      This pic from:
                      PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                      12-15-2023, 10:30 AM
                    • JSin21
                      Compatibility of main boards between different variations of samsung MU6100
                      by JSin21
                      Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                      I have Samsung Smart TV UA65MU6100WXXY version DA01
                      Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                      11-27-2023, 04:54 AM
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • alro7779
                      Samsung UN55MU6103F video problem; has colored stripes on the display
                      by alro7779
                      Hello, everyone!
                      A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                      09-27-2025, 11:29 PM
