i got this set today and it keep power on and off every 2 sec. i notive no vs or va voltage when i unplug all cable on the power supply .the ac detect pin got 5v and drop to 0 when clicking also the main board ave 3-4 green diode and 1 red diode that glow when clicking on the imediately shut off after 2 sec like a infinite cycle.i think the power supply maybe dead or the main board..need advise if you know .
lg 42pc1da on and off power supply problem or ??
Re: lg 42pc1da on and off power supply problem or ??
There are many 3300uF 10V caps on that PSU.....
These go bad and can cause exactly that symptom. As I remember--There's 9 of 'em Change the lot! That should helpTELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM! -
i ave test all one by one out of circuit,all read good .i test the fet and ifound 1 short, replace it ,still no go ...my ac detect pin fluctuate 0v to 5 volt when clicking cycle.. 3.4v ok the rest got nothing ...Comment
'Ah--Ive been having 'fun' with that same set--and its IPM's...
The PSU can be removed from the set, and run on the bench.--Makes life easier to work on.
As I recall, there's a PSU-On pin that needs to be tied to the STBY-5V pin by a 1K resistor, also need to supply the Vs-On pin the same way and the 3.3V-On pin too, so that those supplies become active.
A 100W 240V bulb can be connected to the Vs and Gnd pins--and should light. Voltages can be checked and set.
--This is the way I work on the PSU's of sets,--MUCH easier than messing round with it in the set....
What part of circuit was the dead-mosfet in? Maybe you have other dead devices in the drive circuit to that part....TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
The red spots called, 'Mal-Discharge' are a known issue.
The Control-Board Firmware needs updating using a LG jig and computer with the special software to re-new the firmware with a later version to fix this problem.
'Capkid' in the USA can do this for you as well as myself as we have the jig and firmware-files etc, but I'm based in UK.TELEFIX
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
Assuming...7 Photos -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
