Samsung 50AU7172, only blinking red light
  • norbiszoke
    • May 2015
    • 18
    • Serbia
    We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
    Regards, Norbert!
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Well sounds like BL and PSU to BL works. Should start measuring voltages from PSU to main and make sure they all present. Plus a picture of psu legend. Samsungs generally have a blink code, so how many blinks is red light doing.
    • norbiszoke
      • May 2015
      • 18
      • Serbia
      The red light blinks one time. At the other post where the MU series is discussed there was a post that the boot in one of the SPI chips is bad and thats when the one blink is occuring. But will measure the voltages in a sec.
      • lotas
        • Jan 2016
        • 4859
        • Russia
        Check this area, it looks like moisture has entered, check the HDMI and usb input lines for short and low resistance to ground, put a jumper and disconnect the lvds cable and check for startup without a panel.
        In the MU series, if the spi firmware fails, then the TV is completely dead and the standby indicator does not even light up.​
        • norbiszoke
          • May 2015
          • 18
          • Serbia
          That are is just typical dust from carpet. I cleaned it up. The 13V from PSU and 3.3V standby are present on the board. The 3.3V is there to the 24c512 and the 25q40. The 1.8V and 3.3V are also there at the EMMC. Thre is no short on the USB and the HDMI inputs.
          • norbiszoke
            • May 2015
            • 18
            • Serbia
            What do you mean by putting a jumper? I disconnected the LVDS connector but still the same simptop.
            • lotas
              • Jan 2016
              • 4859
              • Russia
              About this jumper.
              • norbiszoke
                • May 2015
                • 18
                • Serbia
                About this jumper.
                Shorted those 2 pins with the LVDS cable out, but still one blink and nothing else happens.
                • lotas
                  • Jan 2016
                  • 4859
                  • Russia
                  So what diagonal do you have, 50 or 55? What is the panel number? There is a programmer, read all the dumps (3 pieces) ic503, ic501 and ic502 and post them here.
                  • norbiszoke
                    • May 2015
                    • 18
                    • Serbia
                    The TV is a 50" one. Here is the panel number and the number from the backside of the set.
                    • norbiszoke
                      • May 2015
                      • 18
                      • Serbia
                      I can read all 3 of them. I have an RT809H programmer.
                      • Diah
                        • Feb 2013
                        • 6565
                        the main boards photo you posted it belong to 55 size.... the 50 as the lable on the back should be the mainboards with this lable
                        • norbiszoke
                          • May 2015
                          • 18
                          • Serbia
                          I get what you mean, the mainboard was not changed by us, maybe by warranty service or someone else changed the board before us.
                          • norbiszoke
                            • May 2015
                            • 18
                            • Serbia
                            Here are the contents from the IC's 501-502-503. And sorry for taking up your time.
                            • Diah
                              • Feb 2013
                              • 6565
                              warranty service will never replace 55 in 50.. no reason.... the questions have you ever seen this SET working !?.
                              • norbiszoke
                                • May 2015
                                • 18
                                • Serbia
                                No I have not, it came to our shop like this. You can never know what happens here in Serbia.
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  I literally had warranty service replace 50 in MB like 2-3 weeks ago. The warranty guy came with a new panel and new MB/PSU combo. Tried panel, wasn't it and replaced the MB. Maybe in USA they will do smaller tv
                                  • lotas
                                    • Jan 2016
                                    • 4859
                                    • Russia
                                    Try experimenting with these dumps, dump, ic501 is very different.
                                    • norbiszoke
                                      • May 2015
                                      • 18
                                      • Serbia
                                      Will try tomorrow morning.
                                      • Diah
                                        • Feb 2013
                                        • 6565
                                        not good enough this worker... he forget to bring with the RC and the main cord
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                          09-07-2024, 05:50 AM
                                        • 3DDD
                                          Samsung UE46D6100 LED TV blinking red light indicator
                                          by 3DDD
                                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                          02-20-2025, 12:51 PM
                                        • KYBOSH
                                          Trying To Fix: Samsung UN50TU7000 - Weird Fading Screen then Red blinking light
                                          by KYBOSH
                                          Picked this up to resurrect.
                                          When I plugged it in it comes on for about 1 minute... after a minute the screen blacks out and I gets blinking red lights on the power button.
                                          I read that a common issue with this model is a failed BGA so I ordered a replacement on eBay.
                                          Sometimes the TV would produce an expanding blob on the screen before going black.
                                          See Video here
                                          I ordered a replacement board off of eBay and installed it tonight and got the same behavior.
                                          Did I get another defective board or is there an issue with...
                                          09-16-2024, 07:48 PM
