MIP2H2 Sub's
  • mu2
    • Oct 2009
    • 217
    MIP2H2 Sub's
    Are there any good substitutes for the Panasonic MIP2H2?
    Perhaps something Digikey stocks?
    Mike
    Re: MIP2H2 Sub's
    Can't suggest any direct subs but what's wrong with using the same chip?
    http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
    • mu2
      • Oct 2009
      • 217
      Re: MIP2H2 Sub's
      I wanted to see if there might be something on some scrap boards I have that might work.
      I wasn't able to find a data sheet for the original part and I couldn't find a sub with the chips on the scrap boards.
      Ordered the original chip number today.
      Mike
      • Nevillet
        D718 & B688 Transistors - Substitutes?
        by Nevillet
        Hi All,
        I have been given a 40 year old Technics SU-C04 amplifier that blows fuses.
        I desoldered the 4 power transistors and discovered the D718 (PNP) and B688 (NPN) were shorted.
        These don't appear to readily available so I'm looking for substitute suggestions. I'd obviously replace all four so they would be matched pairs.
        I've attached a picture of the transistors attached to their heatsink. Because of, what appears to be, overspill of heat compound, i'm guessing the transistors are not original.
        I've also attached...
        02-05-2021, 03:23 PM
      • Hondaman
        Backup to USB drive
        by Hondaman
        Okay, I fixed my USB problems discussed in another thread. Now I would like to back up some files. I bought a USB enclosure and a 2 TB SSD (I should have saved $50 and bought one without cache, but I bought the more expensive Samsung EVO 570 instead).
        I seem to prefer Linux Mint, although I could probably use Microsoft Backup for Windows 7. I think it still exists. Here's what I did with Mint 18.3 tonight:
        Code:
        cp * -pR "/mnt/win7-drive/users/mike/My Pictures/" "/mnt/usb-enclosure/My Pictures"
        and
        Code:
        cp * -pR "/mnt/iwn7-drive/users/mike/My
        08-29-2024, 11:32 PM
      • clearchris
        Chipquik substitutes - Rose's Metal, Roto136F
        by clearchris
        My chipquik supply is running low, so I did a little research.
        Chipquik melts at 58 Celsius (136 F).
        http://www.chipquik.com/store/produc...ucts_id=210001
        There are a number of alloys not containing cadmium that also have similar melt points. Rose's metal is commonly available on ebay, and at pretty attractive price points. Rose's metal melts between 94 and 98 Β°C (201 and 208 Β°F). A bit higher melt point than chip quik though. The higher melt point could be livable if it had better properties, like being able to be cleaned out of closely spaced...
        04-20-2020, 04:31 PM
      • bussincaps
        MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
        by bussincaps
        Hello All,
        tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
        Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
        eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
        Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
        I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
        08-03-2023, 12:57 PM
      • lcdcaps1
        Component identification
        by lcdcaps1
        Hi
        I cannot find any information on an sot-23 component. It is on a USB board. The markings are 23AX
        There is another sot-23 component next to this one and the markings are 1AM. I have found some information on this one but no information about substitutes
        If anyone has any ideas, please tell me.
        thanks so much​...
        05-09-2025, 05:53 AM
