Flashing Horizontal Lines on TCL LED55p65US in the Jungle
  • Villiager
    • Apr 2024
    • Thailand
    I am in the jungle visiting family and I always try to fix all their electronics while I am here
    A few years ago I gave a family a TCL LED55P65US tv, and now i am back and it is having some issues.
    There are constant, shifting horrizontal lines across the screen and the screen flashes every 1.5 seconds or so, as seen in the attached gif.
    Ive been through a few troubleshooting steps and no luck so far.
    Does this seem like a possible T-Con board issue or does this seem unrepairable? The tv has been in a high heat and high humidity area, and the back is VERY dusty (it's the jungle, no AC)
    I'm planning to take the back out and clean off all the dust, clean and reseat the T-Con ribbons, and then possibly replace the T-con board.
    Does that make sense, or should I try something else? Or is this likely a panel issue?
    Thanks for any help or direction
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • Ihandyrepair
    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
    by Ihandyrepair
    Hi guys
    I just started fixing 4k TV few months ago. so I am still learning a lot
    I got this tv from friend complaint is ghosting or horizontal lines on image.
    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
    then it started to show the ghosting white image.
    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
    it has 3 thin small boards at the bottom of the...
    12-05-2022, 04:18 PM
  • ggil44
    Sony XBR-65X750D Horizontal lines bottom of screen
    by ggil44
    Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
    05-30-2023, 07:51 PM
  • noisykid
    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
    by noisykid
    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
    12-30-2024, 07:15 PM
