Samsung UE50TU8000K Boot loop.
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Ok team. Let’s see if the finest minds on Badcaps can deliver the goods yet again.
    Done the usual disconnect PSU from main board and get good result for steady backlight. Panel buffer boards seem in good health with a very small impact damage to one of them that could have been caused by me during disassembly. However when powered up the backlights still remain on so I’m confident there has been so significant damage to those buffer ribbon cables.
    I’ll go through the MB with a fine tooth comb looking for shorts but what are the suggestions in the mean time?
    The first time I powered up before disassembly I did very briefly get a dull screen with the HDMI screen on display before it went into boot loop.
    Special shout out to the special forces members of lotas & Diah
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    To add to this. When I test the small SMD caps in the area of the board around what I believe to be inductors (marked 2R2) I get good, solid readings with caps that begin to discharge very slowly.
    And also the same good readings around the Ic VPMS2SM DA2037 SMPF 019, good, steady readings on the caps in that area.
    When I move to test the ones in the area of Ic marked TAS5749M 09W G4 CFC6 the multi meter jumps around between micro and nano farad without ever giving an actual value.
    However. I’ve read the forum enough now to understand that Samsung is famously bad for firmware failing. Is there a test I can do for this to confirm or should I simply bite the bullet and order a CH341a programmer?
    • lotas
      • Jan 2016
      • 4660
      • Russia
      Place a jumper and disconnect the LVDS cable from the motherboard, turn it on and see if it reboots or not, if there are no reboots, then there is a problem in the panel.
      This is not a series where the firmware fails; the “TU” series is very famous for having a non-working panel and backlight burnout.
      • Donny2derby
        • Apr 2023
        • 228
        • Uk
        Lotas this is excellent. I will do this immediately. Whilst I prepare the jumper kindly explain the purpose of this test.
        Ok lotas interesting. The panel goes into bootloop 2 or 3 times then give a maintained and steady backlight. So does this indicate the screen is ok and we should continue with the fault finding?
        I have seen in other threads to check for 12v from Ic1603 Ut to buffer boards. But I’m struggling to find a pinout for the Ic.
        Exciting progress though!😀
        • Diah
          • Feb 2013
          • 6399
          you said that you saw HDMIL on screen at first time... can we see the panel buffer boards complete.
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            Yes the very first time I powered on Diah. But I also tried twice more before initial disassembly and it did not go to HDMI screen on those 2 next attempts at power on.
            Set is no safely secured away in secrecy at work. The next shift returns soon so I need to tidy away haha. Hopefully I can continue the process tomorrow or if not then most definitely can continue with work on it Saturday night onwards when I am on night shift.
            lotas do you think it will be good idea to order CH2341a programmer in mean time in case you recommend software update?
            Thanks to you both for help and support as always 👍🏻
            • Donny2derby
              • Apr 2023
              • 228
              • Uk
              lotas Diah
              Where do you lads suggest I go with this fault finding now? What is next stage of process? Should I check for 12v from Ic1603? I have noticed that there is a small dot on corner of this Ic, does this indicate where PIN number 1 is?
              Kindly advise of next steps to take.
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                lotas
                I’ll be getting this TV out of storage later to continue the repair work on it.
                Im going to attempt tape method on it first. Am I best off removing the jumper wire you asked me to install first or not?
                Diah I’ll get the picture of the buffer boards up as well. But you’ll probably be tucked up in bed when I do haha.
                • lotas
                  • Jan 2016
                  • 4660
                  • Russia
                  Hi, show me a photo of the damage to the buffer tapes first, maybe there will be no need for further repairs.
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    Ok mate.
                    It’s an hour or so until I will retrieve the set from where it’s being kept.
                    The damage is only very slight. Almost like a small part of one of the tab has become slightly depressed. I wouldn’t imagine it has actually caused any damage to the panel or image.
                    • Donny2derby
                      • Apr 2023
                      • 228
                      • Uk
                      Ok mate. Photos of panel tabs below with buffer boards also included.
                      I hope you can make out the very small amount of damage to the tab I’m referring to.
                      Should I try tape method? Or do you have a different suggestion?
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        Ok lotas I decided to jump in and attempt tape method and progress has been made.
                        With the tape on this part of the board I get the below image.
                        • Donny2derby
                          • Apr 2023
                          • 228
                          • Uk
                          And now without any tape at all the image appears clearer! This is with the link installed you asked me to a few posts back.
                          • Donny2derby
                            • Apr 2023
                            • 228
                            • Uk
                            Ok stand down lads.
                            Cracked screen. And the worst of it is I think I’ve done it!!
                            • Takeatry
                              Yet another Samsung QLED Boot Loop
                              by Takeatry
                              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                              10-04-2024, 02:57 PM
                            • torchzack
                              Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                              by torchzack
                              Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                              I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                              Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                              08-28-2023, 07:42 AM
                            • NolesFan
                              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                              by NolesFan
                              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                              10-24-2024, 06:36 PM
                            • eigma
                              Samsung UN40H5003 boot loop every ~8 seconds
                              by eigma
                              Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                              Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                              SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                              Main board: BN94-07592P / BN97-08922R...
                              11-20-2024, 10:31 PM
                            • blaster_
                              Samsung UE49MU6105K - boot loop, horizontal lines
                              by blaster_
                              Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                              Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                              06-22-2022, 05:19 PM
