I Need T-Con Fuses!
  • max1636
    • Dec 2013
    • 80
    I Need T-Con Fuses!
    I'm after a couple of T-Con fuses for when I get TV's with blown ones so I can fix them properly instead of using car fuses. I'd like to get them from Digikey but I've found they have tons of options. I'm just after a few 2A, 5A and 7A fuses (those are the common ones right?).
    Could somebody bring me up a page at least with the 5A Fuses, Thanks.
  • mockingbird
    • Dec 2008
    • 5488
    Re: I Need T-Con Fuses!
    Would I be mistaken in assuming that you would be required to know the voltage in addition to just basing your replacement on amperage?
    What kind of fuses are they, SMD or just regular through-hole axial glass fuses?
    • max1636
      • Dec 2013
      • 80
      I was assuming people on here know what voltage they are but I believe they are 12v.
      • mockingbird
        • Dec 2008
        • 5488
        Here you go mate:
        http://australia.rs-online.com/web/c...cuit-breakers/
        • max1636
          • Dec 2013
          • 80
          Thanks, Guess I'll just have to spend some time to find a match.
          • max1636
            • Dec 2013
            • 80
            So this is what I've found, I actually used Digikey:
            Fast Blow:
            http://www.digikey.com/product-detai...87TR-ND/700828
            Slo-Blow:
            http://www.digikey.com/product-detai...47TR-ND/552287
            Anybody know which would be better for this application?
              Surface Mount Fuses Fundamentals Datasheet
              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
              10-07-2024, 06:07 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
