HI I have a break in the EHT wire that connects to anode that goes into the tube i.e noticed light beaming out from a tiny section of the wire and sparks on a component on the pcb.Please advise the best method to repair the eht wire i.e what type of glue can i use.thank you.
DIAMOND CRT TV MODEL DTV-29T 76 TRUE FLAT TV
by wnlewisOK. I got the rocker switch figured out thanks to the good advice on this forum.
Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
This is a Whirlpool RDE3340 electric range.
The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
Where may I find parts... -
by emeskayWe have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...1 Photo
I currently have a customer's vintage fan on the work bench to repair.
It uses an induction motor with 4 poles. One of the poles is open.
I couldn't find the break so i cut off the original wire.
I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
The enamelled copper... -
by sam_sam_samI was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap... -
by dclass-proHi all guys, I need your help. On a HP 440 G2 - LA-B181P laptop I was changing the speakers and the pc worked fine everything ok.
After closing it all with all the screws I realized that it would no longer turn on. I opened it and found that the flat cable of the LCD was shorted. I ordered a new flat but the motherboard still won't turn on, as soon as I connect the power supply the connector LED always flashes and the power button stays on.
I tried to check the voltages and the 3v and 5v are there, on the battery pin (with no battery connected) I have about 2v.
I tried to... - Loading...
