SONY KDL-52W5150 No Picture, Sound and Menu are Ok
    Hi Guys,
    Need some help with my only SONY KDL-52W5150 TV. The TV work till yesterday just fine. Today I tried to watch a movie but no picture on the screen. The sound is fine and menu works fine too. Was reading the Martin's guide, and looks like I have a bad T-con, not really sure if that is the problem.
    I have 2 devices connected to my tv: computer (hdmi1) and comcast box (hdmi2). Both of them have no picture. I like to fix things and for me not a problem to open the tv and do something with it.
    Re: SONY KDL-52W5150 No Picture, Sound and Menu are Ok
    After 5 hours of trying it start working again. Don't understand the reason but I hope it will work 3 more years.
      In your case, I would reset (remove and replace) all connectors. Inside and out. And check for bad solder joints on the boards.
        Thanks, will do it if it happens again.
          If your menus work the Tcon is fine. This is a mainboard fault. Do you have a snowy picture on tuner mode ptr can you get a picture with composite video (yellow red white connectors) or component inputs? If so your HDMI codec processor is failing or failed on the mainboard.
