SONY KDL-52W5150 No Picture, Sound and Menu are Ok
  • homelyn
    • Jan 2014
    Hi Guys,
    Need some help with my only SONY KDL-52W5150 TV. The TV work till yesterday just fine. Today I tried to watch a movie but no picture on the screen. The sound is fine and menu works fine too. Was reading the Martin's guide, and looks like I have a bad T-con, not really sure if that is the problem.
    I have 2 devices connected to my tv: computer (hdmi1) and comcast box (hdmi2). Both of them have no picture. I like to fix things and for me not a problem to open the tv and do something with it.
  • homelyn
    • Jan 2014
    Re: SONY KDL-52W5150 No Picture, Sound and Menu are Ok
    After 5 hours of trying it start working again. Don't understand the reason but I hope it will work 3 more years.
    • truep
      • Aug 2010
      • 373
      In your case, I would reset (remove and replace) all connectors. Inside and out. And check for bad solder joints on the boards.
      • homelyn
        • Jan 2014
        Thanks, will do it if it happens again.
        • freakaftr8
          • Oct 2012
          • 3743
          If your menus work the Tcon is fine. This is a mainboard fault. Do you have a snowy picture on tuner mode ptr can you get a picture with composite video (yellow red white connectors) or component inputs? If so your HDMI codec processor is failing or failed on the mainboard.
          • DKWS89
            Sony XBR 49x900E - Sound and backlight on but no picture
            by DKWS89
            Hey Guys,
            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
            12-14-2023, 04:30 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • ronni
            Sony KD-43XE8005 with sound, backlight, no picture
            by ronni
            I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
            When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
            Removing the LVDS cable results in...
            12-01-2022, 08:44 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
