Red light but no power - alba tv please help
  • SmartestSmarty
    replied
    Re: Red light but no power - alba tv please help
    Thanks for all your help.
    I have another TV to repair; I'll start another thread for that one and post the link on here also.
    I look forward to repairing the next one.
    Thanks again
  • flocko
    replied
    Good job hope you continue to learn on here and find more sets to repair Flocko
    replied
    Good to hear, enjoy your TV.
  • SmartestSmarty
    replied
    Yes the board numbers were exactly the same. No worries I found the issue, I put one of the ribbon cables in upside down. Its all working now
  • flocko
    replied
    Do all the numbers on he old main board match the new main? these have to be a complete match, also on the plug that goes to the T.con these board some times have more pins on the board then on the plug and needs to be fitted the same as the old one? so check these thing and reply Flocko
  • SmartestSmarty
    replied
    Hello all,
    I completely changed the main AV board, the screen now comes on, but I am getting only a white screen. Any idea why? or how to resolve this?
    replied
    See here for how to test voltage regulators
    https://www.badcaps.net/forum/showthread.php?t=22231
    try that on your board.
  • SmartestSmarty
    replied
    Thanks. I am looking for a replacement board; however, I wouldn't mind attempting to fix this one myself. I can solder very well, and I'm sure there will be a youtube video out there explaining how to do SMDs. I don't mind if I need to purchase a different tester off of ebay or something. As you can see I like to learn and do things for myself.
  • flocko
    replied
    Bad capacitors are to blame in about 5% of Tv repairs and cannot be tested with a multimeter.And as most of the part fitted to your main board are SMD and would need highly skilled soldering for there replacement a replacement board is your best bet. Flocko
  • SmartestSmarty
    replied
    Thanks for the reply!
    Are you sure? I am willing to give it a go; I have to learn someday.
    I know how to change capacitors. So if you think It may be a bad capacitor, maybe you could tell me how I test them; and then I could change any bad capacitors if needed.
    Kind regards.
  • flocko
    replied
    been out cutting grass,well as Tom said 12 volt supply are there i thinks the 5V from the main must be there as well for the red standby led to light, so my best bet would be bad main board. and as such i would suggest a replacement board as i would think that testing and a repair on this would be beyond you at the moment.Look for part number on main board then search on Ebay. Flocko
  • SmartestSmarty
    replied
    I appreciate all the help,
    Do you need any other pictures?
  • SmartestSmarty
    replied
    Originally posted by tom66
    Time to look at the main board, can you post a picture of it?
    Originally posted by flocko
    on that socket or near by is there any thing screen printed to tell us what should be there it could also be on the other end were it go`s to main board has the power board got a part number on it?
    In the centre of the power board it reads, ACT 3611 / ERL28-T002 (Is this the board part number?)
    This is what I can see.
  • flocko
    replied
    Sorry just looked at your photos again and your power board is mounted to the plastic body of the set so the mounting screws would not be grounded flocko
  • flocko
    replied
    replied
    It would appear the power supply is working then. Time to look at the main board, can you post a picture of it?
  • SmartestSmarty
    replied
    I tried again this time I got.
    Red Wire: 12.71
    2nd: 12.71:
    3rd: 12.71
    4th: 0.00
    5th: 0.00
    6th: 0.00
    7th: 0.03
    8th: 0.00
  • SmartestSmarty
    replied
    OK, I tried it again, this time I got.
    Red Wire: 12.71
    2nd: 12.71
    3rd: 12.71
    4th: 0.00
    5th: 0.00
    6th: 0.00
    7th: 0.03
    8th: 0.00
  • SmartestSmarty
    replied
    You can't be testing it correct then, if you get 0V there the power light would not work. Show us what your meter is set to please.
    Is this correct?
    replied
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • russpall
    LG 39ln540v - red light flashes twice, no power to LED driver?
    by russpall
    Hi there,
    I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
    The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
    08-27-2024, 01:07 PM
    by sam_sam_sam
    03-31-2024, 02:12 PM
    Laptop computer that went completely dead no boot no power light no hard drive light
    by sam_sam_sam
    See pictures for type of laptop computer
    I checked switching power supply brick 19.2 volts multi meter only
    No booting without switching power supply connected
    Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
    What the heck is going on here...
    04-04-2025, 04:58 AM
