xbr-75x950h 8 blink
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    xbr-75x950h 8 blink
    Got this TV. Turn it on, shows Sony logo and stays for 20-30 second. Then restarts, does same thing (never gets to Android logo) and after second time it shuts off and does 8 blink code. Slight research says software failure.
    It's hard to navigate badcaps with new UI, so anyone have a link or process to update software on this? Videos on YouTube are of hindi guys with super old tvs lol. Thanks.
  • EazyBone
    • Jun 2023
    • 1350
    • United states
    Actually ignore all of this. I noticed the TV had been opened and when searching the board I found a xbr75x900e main board in here instead of the correct one for this TV so I don't think software update going to do anything since it ain't for the TV.
    • jojo88
      LG LED (LCD) TV 50LN5600-UI flashes logo, red LED 3x blink
      by jojo88
      This 50 inch LG LED (LCD) TV was given to me not working. Powering it on, the logo flashes once for 1/4 second then black. Front panel red LED blinks 3x (I think... see below) then the LED turns off. TV stays on until I press the Power button again. There is an image on the LCD panel--I press the "Settings" button on the TV and this brings up menus I can see with a flashlight / torch.
      (The front panel red error code LED blink sequence is a bit confusing to me. The LED is on when the TV is off. I press the Power button and the LED *very briefly* goes off--maybe 1/10 second--then...
      03-29-2023, 11:20 AM
    • Verlengsnoer
      Bios splash/logo change
      by Verlengsnoer
      at firs, i hope this is the right place to post my question.
      Im looking for a tool to change the bios logo.
      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
      i know that HP has a build in option to change the splash logo.
      but i want to change the manufacturer logo to an own logo.
      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
      10-28-2022, 09:52 AM
    • cloo
      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
      by cloo
      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
      After doing a factory reset this problem was gone and the picture was back to...
      01-06-2025, 06:02 AM
    • EazyBone
      Un50cu7000 2 blink oddity *partially solved
      by EazyBone
      I write this to maybe help another with this TV.
      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
      03-18-2024, 10:24 PM
    • Vebririon
      panasonic TX-P50V10E 6 blink led problem
      by Vebririon
      I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
      Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
      I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
      05-17-2025, 10:16 AM
